haha no pressure. I actually have a friend who just did his first cycle, has a week left and put on about 8kgs. We think he will drop bit of that weight cause he said he put most of it on in a week or two.. was interested in how much Vspec managed to keep.
I cant really risk roids due to having a heart condition called ARVD especially if all I was hoping to gain and manage to keep is like 4-5kg, which is a good gain i realise but the risk to the reward not really there.
Too many downsides to the roids that I could afford haha!
Doing it natural will be far more satisfying in the long term imo
On another note, I did the seated behind the neck press for the first time today. I liked it, managed to push out 5 sets of 8 (only made 7 on the last set) on what I think was 60kg. I think I'll alternate between it and dumbell shoulder press from now on!
Edited by Mitcho_7
Military = standing press, whether behind neck or not, to my knowledge. It's also traditionally done with a barbell. If you're doing it standing, make sure your knees are slightly bent to preserve your back and put one foot forward.
I never do it behind the neck, I have been told by a few trainer it's actually bad for you
Yeah...f**k that. They say the same about lat pulldown. It might be riskier for injury, but I have been doing both exercises behind neck for many years with no adverse results. You do need to have a good technique and build up flexibility to pull off a decent range of motion (i.e. touching neck), though.
I like behind neck because it isolates the delts and you can't really "cheat" by involving your chest.
Good advise Birds, I'll keep that in mind.
What are you guys doing in terms of barbell military press? I'm finishing up on 55kg barbell.
(mind you I'm Asian, 6 ft, 86kg, can't get any stronger.. been plateauing for ages)
Military behind neck and touching it, 40kg x 10 on the first three sets, 50kg x 10 on the last three. 79kg 6'3
What sort of body fat do you estimate Johnny?
I am not too sure to be honest, never really looked into that. I am bigger than all my asian mates, and on a good day can bench 110kg with some spotting.
I find that I can't get any stronger, and if I start eating a tad less I shrink. I'm a tad flabby, like not defined.
Probably 20% body fat?
Oh, so Birds is a guy, cheers Mitch
Sorry about that Birds, odd username
All good brother, had the nickname since I was young and my avatar doesn't help :)
That being said, I know a girl who is about 6'5 and her boyfriend is nearly 7' lol.
I think if you doing any form of resistance training you're going to get gains from it in the long term. But tailoring that program to suit your goal is what will yield the improvements you are most keen to see.
That has been one of the smartest posts i've seen on here.
Crossfit works, cardio works, powerlifting works, weightlifting works, bodybuilding works...it all works. Just depends what YOU need from it.
Does frequent masturbation work?
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
