Do they all come with their arms ripped off or is that the R-Spec model? (cwatididthar?)
Edit: damn, thought this was Vic wasteland, my joke will go unappreciated :(
not sure what you did there lol
yes they have no arms. sif dummies hit back
Vic wasteland whore checking in
Try eBay Rimon?
nothing cheap/local on ebay
No verdict as such, but I can vouch for vanilla (very subtle taste), chocolate, and banana (tastes just like banana lollies). Vanilla is my favourite due to highest protein:carb ratio and it being such a simple flavour, as though it simply had some vanilla essence in milk
I think I'll go the vanilla then. After my last experience with trying a new protein powder I figured I'd do some checking before i go balls out and get 5kg of the stuff.
How's that injury going Troy? Any diagnosis yet?
Going well to be honest. I got some Voltaren 25 and immediately felt great! Suggesting that you were likely correct on that it was sacroiliitis...So I'm just avoiding loading that joint until at least mid-way to the end of next month.
Oh also xray showed S1 isn't fused to the rest so in effect is acting as L6 - an additional lumbar vertebra. Though that's apparently fairly common, could contribute to excessive movement in the SIJ?
Has anyone ever used BNRG Proto Whey? I bought the banana flavour ages ago and it has an after taste of cheese hahaha. I swear my taste buds are screwed or something but it's so disgusting to smash down.
It's soul killing to find out the new protein powder you bought tastes foul, especially when you got 4.5kgs of it haha!
You build up a tolerance to the taste after a few weeks of just necking it though
Involuntary weight loss time, negative emotion kills my appetite and at this point I'm stressed as fuark. Drove home starving at 330, received shit news, had to force myself to eat dinner at 730. Shit.
Just purchased myself a body fat % pincher thingo.
If my funds allow me to then I will also jump online and get me some choc powder
I believe you are referring to skin calipers. Do you know the points on the body to take readings?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
