bahahaha
- double decaf short soy late, no sugar - heavy on the estrogen, light on the testosterone
You drink milk at home lol
You get outta here no one invited you
rofl I have to live with that.
It seems like Troy killed the thread.
So I am bringing it back.
After having all you broad minded persons rip on me about my soy milk.
I have cut that out and been drinking my BN with just water.
Haven’t noticed a loss in weight or gain over the past week and a half.
This could be the fact I am replacing my fat with muscle at the same rate?
a week and a half?
nothing will be noticable in a week and a half mate.
Don't micro measure.. especially in terms of weight.
If you are about looks - then go off what you see in the mirror.
if you are about strength - look back in your log for what you were lifting or failing on a month ago.
Changing from lady milk to water in your protein "suppliment" and then thinking that since your weight hasn't changed, it must mean that you are burning fat and replacing it with muscle is retardation #1.
My bad I should be giving myself a lot longer then.
It feels like I hit a plateau over the past few weeks because I havent noticed much of a change in the weights I can lift or my look.
But yeah this is probably due to me micro measuring
Definently start hitting the freeweights!
Machines have there place (like the high/low pulley cable machine) and are good to change things up, but free weights form the basis of a lot of my sessions.
Also, probably don't cut out milk all together. If you struggle with lactose intolerance maybe try that zymil milk or whatever Is that is lactose free.
You trying to start some shit here mate? Don't f**kin talk smack flamin mongrel step up!
And get a membership, I'd recommend coming to Anytime in Tuggers with me coz my gym buddy is gay and always goes late now, but that's too far for you hey?
That would require me to do it after work which I couldn't be f**ked. Might go check out fit was first next door to the hotel
Daniel, you only use machines because that all they have
Lucky you dont go to clubs with fat old hairy blokes dancing around, because your sex life would suck
You would probably just go to a different club, hey
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
