They are primarily nothing...what they work depends on how you do them, as there are many different styles of deadlifts. Off the ground in a full squat position is going to have more leg involvement, where as stiff legged with minimal leg bend will target your lower back throughout the range of motion.
Just see what muscles give you DOMS I guess, then you'll know what your deadlifts are "primarily" working lol.
What do you think the lumbar erectors are?
Erector spinae is the blanket term for the muscles that run parrallel to the spine.
There is iliocostalis lumborum, spinalis dorsi and longissimus dorsi all in the lumbar region. Deadlifts will also hit quadratic lumborum, but it's not grouped in with the "erector spinae" term.
It's just habit for me to refer to them as lumbar erectors to be slightly specific without naming them I guess...
Edited by Mitcho_7
brids was right, depending on how you do deads will depend greatly on what muscles are used the most and at what point.
i find normal deadlifts (where you actually hit the ground and reset every rep) to do the entire body, however if i lower the bar to near the ground without actually touching, it hits my back a thousand times more, I also find that I can do more reps this way.
sumo deads will do your arse and back more, stiff I find hits my hammys etc etc
Trying to decide if I should be getting something now to bulk up a little or just stick with it and increase my eating.
I have lost a total of 8kg over the past few months now since starting.
Currently sitting at 69kg 170cm
When you make up your mind let me know, I might be keen on getting some more stuff.
News just in guys.....
The gym and supplement Discussion world came to a screaching hault today when a 69kg man questioned wether he should start bulking up a little.
One witness was quoted as saying "dafuq?"
After some investigation it was found that the 69kg man [man...lol.. yeah right - Editor] was in fact studying to become a Bosu Ball instructor and so the shocking news was not so shocking but still quite queer.
Edited by TTT
I would just increase your eating like you said. You can make a DIY weight gainer (grinded oats, PB, milk and whey) which is pretty convenient. tastes alright as well.
Edited by Dani Boi
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
