try explosive/plyometric stuff for your calves... weighted jumps, hops, sled pushing etc
Would explain why quite a few tennis players seem to have decent calves for their body size...
I would agree that it is mostly genetic. But I have also read others have had good results with using a combination of standing and seated calf raises, 3 times a week give or take. Also, to target the left/right sides of each calf, you can alternate between pressing up with the big-toe side of the foot and the pinkie side of the foot. But apparently it's not so good to actually rotate the foot (toe-in or toe-out).
Travel back in time, and find a way to be an egg in another ovary to your mums and also find a way for another person than your dad to exploded in there.
No wonder you have a 1 star rating on here..You honestly are just a dumb meat head.
Do you even lift brah ?
Daniel, you serious mate? TTT has a lot of experience...
I dont doubt that he has experience.
But his experience makes him look down upon the people who dont have as much experience.
Everyone has to start somewhere and I bet he didnt just wake up one day knowing the meaning of life
whatever you do with calves, do it until they burn, I find between 10-15 reps works well.
gaining size on your calves is difficult as TTT said, alot of it has to do with genes. With that being said mine have grown.
also what Birds said, hill runs or even just put a real heavy pack on your back 20kg+ and go bush walking, your calves will grow after a few months of doing that.
Going to read into thise explosive training for calves, will try weight jumps tomorrow though. A lot of people say just squat to get calves, but I do that 3x a week anyway and not seeing any difference really.
Dont want to end up like dis.
I'm assuming you mean genetics? I don't know, I don't really believe in that whole "I cant grow calves so it must be my genetics", they'll eventually grow with the right training, they just might take longer.
Edited by Dani Boi
Hahaha holy shit! Looks like a stiff breeze would blow him over.
I bloody love training legs.
Full range of motion needed for calves too. Mine often cramp up because they're so tight though.
of course you can improve the size and shape of your calves.
But take that guy in the picture above, he can throw everything he's got at calves, and they will grow a little and change shape a bit, but they will never look like the calves of a trucker as Birds said earlier.
your genes decide how your muscles are in regards to the width, length, where it ties in behind the knee and soleus.
depends on your make up of fast twitch or slow twitch fibres.
when it comes to calves you can improve what you have, but there will be people who have awesome calves by walking tot he kitchen and back.
Google "doggcrapp calf training"
try it out.
I strongly suggest you ease in to this and don't just go do the reps and sets suggested straight up.
I'm serious. you will not be able to walk.
doggcrapp training in general is pretty good stuff for those of you image inclined peeps.
I think higher reps ranges are the go for calves like people have said. I have crappy calves, my gastrocnemius are literally only 1/3 of the length of my shin so im never going to have big calves due to genetics. I usually pick a weight and go til failure, with both a seated and straight legged exercise . Calves would be predominantly slow twitch fibres due to there function in everyday life and your type IIa fibres will have taken on the characteristics of type I fibres if all you do is walk around.
Edited by Mitcho_7
higher reps for calves? the fckers are used to carrying your body weight for hours at a time doing god knows how many reps... you have to shock them, force them to adapt by doing something different
I have always had decent sized calves (nothing spectacular) not sure about my genetics but I've played basketball for nearly 20 years... just like tennis, basketball is played on your toes a lot and all the jumping and sprinting is demanding for the calves
This. Let the strength gains put on the kg. People get too caught up in weight figures when trying to get big, which are meaningless without BF% to back them up. It kind of mystifies me when someone says they would like to weigh xxxkg or set weight goals without knowing what they'll look like at that weight.
Also big on power to weight ratios. Putting on fat is only going to reduce this! I love being light at 79kg and benching the same (and sometimes more) than my 100kg friends.
Exactly, when I started I was the old...'I wouldn't mind being around 80 but it be muscle, not fat' Im not near there now and don't mind,
I'm still gaining strength.
Started back on deads and squats tonight after a six week hiatus (flu + cold, thanks). I decided that, rather than getting depressed over not being able to do the same weight/reps as before...or using shitty technique to obtain them...I would seize opportunity to start fresh with perfect technique and low weights.
Where I used to squat to parallel, I thought I'd give ass to ground a go at half my normal weights. My problem with squatting to parallel, has been that it's tough to judge if you are actually making it to parallel. It's also very easy to cheat, whether you are decreasing your range of motion later on in the set or involving more back muscles to help get it up (ala good mornings).
So I started with a warm up set of 10 @ 40kg. When I lifted the bar off the rack I laughed at how light it felt compared to 100kg+. In fact, the first rep felt like I had nothing on my neck. However, 10 reps later and I actually started feeling it. Up the weight went to 45 and then 50...the latter of which left my legs almost as sore as 100kg parallels did previously (probably helps that I haven't done squats for weeks).
The most satisfying thing about this experience, was knowing that my range of motion was at it's limits; that every rep in the set had the same ROM. I couldn't cheat in any way and my back stayed as straight as an arrow. The weight was also very much on my heels, where it should be. After I was done my legs felt much more comprehensively worked than parallel squatting.
Now I know the weights weren't high, but I was surprised at how much I could do considering I'm effectively doubling my ROM. I expected even half my normal weights to be a struggle and it wasn't...it just worked my legs much more thoroughly and satisfyingly - hard to explain. I urge everyone doing parallel to give it a go, I'm definitely a convert. Will be interesting to see how long it takes until I'm doing what I used to do to parallel.
Now mentally hypercritical of people doing half squats at high weights lol. Humans = hypocrites.
I remember doing 100kg to the point where you were effectively resting on maximum ROM for 3 seconds - ass on heels - and then standing back up BUT NOT LOCKING OUT KNEES. Repeat for 8 reps.
Then try to walk out of gym.
The walking part didn't work.
Legs said no.
I would love to be able to squat properly (ass to ground style), but my flexibility doesnt allow it at the moment and my right knee doesnt seem to be a huge fan of trying to go lower than parrallel either.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
