Need some advice. Been running starting strength for ~6 months and I want to switch up.
Gone from 5'8 65.3kg to 73.5kg
Lifts
Squat 3x5 - 100kg
Deadlift 1x5 - 130kg
Bench 3x5 - 77.5kg
Was thinking of switching to http://forum.bodybui...=4195843&page=1
The only thing I don't like about it is it doesn't use conventional deadlifts.
Edited by Dani Boi
Lifts
Squat 3x5 - 100kg
Bench 3x5 - 77.5kg
You've been doing SS so I assume strength is what you are after.
here is something that's been posted before.... I'm sure you can work out who it's from
You are a beginner if you cant bench 100kg, squat 140kg and deadlift 180kg. I dont care what your bodyweight is, get bigger, its why your lifting. Bodyweight is not an excuse.
I posted this up on another forum a year ago. The pissweak pencil neck poindexters all pointed out that it was biased against skinny guys. Crap. If your skinny, eat something. At the time Max weighed 60kg and wasnt remotely close to any of those lifts.
One year later he only has the bench to go, he is only a handful of kg's away. That sounds about right. If you train correctly, you should be able to achieve these goals in a year, regardless of bodyweight. Not many on here lighter than Max was, so no complaints.
The record for achieving all these lifts at PTC from complete beginner was Vocy, he did it in under 3 months from never touching a weight, he weighed 100kg. Benny did it in roughly the same, around 10 weeks.
Now, if your a beginner, here is what you need to do, for between 3-12 months.
Squat 3 x 10
Bench press 3 x 8
Bent row 3 x 8
Military press 3 x 8
SLDL 3 x 8
BB curl 3 x 8
Do this 3 times a week. Progressively add weight.
If youve been training for longer than 12 months and cant make ALL those lifts, you've been kidding yourselves, wasting your time on rubbish.
If somebody gave you a pile of ****, and said it was free, would you keep it, simply cause its free? Of course not, you have no use for it.
Just because something is free doesnt mean its useful.
Edited by TTT
Markos is a straight shooter!
When it's says if you can bench 100kg, squat 140kg and dead 180kg is that 1rm or the 3 sets of 8?
I really hope it's the 1rm otherwise I got a long way to go...
Edited by Mitcho_7
What are your goals?
You can always modify the program to include regular deads
Originally my goals were just to be lean with some size but times have changed now. It's more rewarding for me seeing the numbers go up on the bar than to look pretty in the mirror lol. I still would like to stay around 12% bf though.
I originally did SS because it was a highly recommended program on bb.com for putting on mass all over and well it's done that and I actually enjoyed it, highlight of my day lol. I still want to center my training around the big 3 but change up the rep scheme a bit so I'll do what markos has written there. I'm assuming the SLDL will help put the numbers on conventional deadlifting even if I'm not doing them? Got any good instructional vids of SLDL, never done them before?
youtube will have plenty.
Stiff legged deadlift is performed with the legs stiff...
you have a slight bend in the knee so that they are not locked, and keep your back tight.
lower the bar as far down as you can go without losing tightness in the back and without bending the knees any more.
if you are like 99% of the population, you won't have the flexibility in your hamstrings and butt to get the weights to the floor without your form breaking down.
it's not like conventional deads where you return the bar back to the floor.
it is a continuous set without a deadstop at the bottom.
or stick to your normal deadlifts if you want.
question. if you enjoy SS and have not been stuck on a weight, why are you changing?
have you been eating and drinking milk as per SS suggestions?
5/3/1 is also a good strength program.
From my understanding you can do SS for ever really, deload and start again.
Just remember that this stuff take years of consistency and dedication so stick to it and don't let a plateau discourage you.
I gave it a shot (5/3/1) little while back, was tough but I gained some good strength from it.
Haven't tried SS but I use a lot of rippetoes videos and articles regarding form for my training. His deadlift and squat tips are always good and I recommend any newbies I meet to watch/read them.
I train in more of a bodybuilder style, but i think my size/strength ratio is pretty good.
Stats: 179cm, 87kg, 24 years old
Deads - 180kg - 1x8,1x7,1x6
Squat - 140kg - 2x8, 1x6
Bench - 100kg - 3x8
Military press - 55kg- 3x8 (so hard to get strong at this!)
Wouldn't deadlifting and squatting 3xper week be a bit much?
For me to progress on any lifts on SS it takes me the third attempt to do it, so 2 weeks to increase 2.5kg on squat, 1.25kg on bench, and 2.5kg on DL. Seem a bit slow considering my current experience or is this what I should be progressing at? I don't follow GOMAD but I do eat 3500 calories a day which gives me an average of a little over 1kg a month and as I said before I would like to stay around 12%bf.
If you think I should just stay on SS then I will do that, I just wanted to change because I wanted to see if another routine would yield me more strength/size gains.
I'm sure that there are ways to stay at similar fat % and gain strength and size, but it just seems silly to me.
it's like wanting to run a faster 1/4 time but saying I want to keep the prius.
you're not going to get much stronger or bigger if your focus is on your abs.
I'm not saying blow out to be a lard arse... just saying do and eat what is required to get to at least the Novice level and then decide which way you want to go.
I did a deadlift comp on the weekend and a 56kg girl deadlifting 145kg
You are 73kg and doing 1 set of 5 at 130kg
Totaly up to you what you do, but don't expect any gains when trying to maintain a body fat %.
Squat and deadlift 3 times a week is not too much work.
especially if you eat enough.
Figjam - porbably because it's hard to pack 70g of powder in to a fishoil size pill.
not the same thing but you can buy BCAA tablets.
Wouldn't deadlifting and squatting 3xper week be a bit much? For me to progress on any lifts on SS it takes me the third attempt to do it, so 2 weeks to increase 2.5kg on squat, 1.25kg on bench, and 2.5kg on DL. Seem a bit slow considering my current experience or is this what I should be progressing at? I don't follow GOMAD but I do eat 3500 calories a day which gives me an average of a little over 1kg a month and as I said before I would like to stay around 12%bf. If you think I should just stay on SS then I will do that, I just wanted to change because I wanted to see if another routine would yield me more strength/size gains.
It never hurts to try something new, all programs work some may suite you better than others and you can only find out if you give them a go
serious question, why isnt there protein pills?
I'm speculating here but I think the actual molecule size of protein is too big to actually get any benefits from making pills.
An average size pill wouldn't contain much protein so its just not worth it really
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
