Woah, I thought my diet was a pain in the ass to upkeep.
Girls I don't plan on kissing again ;)
Birds, you sir are the initial reason I stepped up my game.
You continue to provide solid motivation to this day. I commend you my fellow man.
alright you lot...
what's your best time at 300m Rower??
Are we using the same rowing machine guys? I swear to god I could smash 300m in under 3 minutes, but I never use the rower so there's a VERY good chance I'm misleading myself.
Markos, it would depend on his level of activity and conditioning obviously (not to mention body type and figures), so how much would you recommend then?
While 210g may be too much for him, it doesn't mean it would apply to all of your lifters.
For example I'm 87kg, lifting 5 times per week. If I consume 210g that's 2.4gr/kg/bw which is a pretty damn solid intake and my body sure wouldn't effectively use more unless I started training twice a day.
hrms.. I consume nearly that much program a day too, but told that's not enough
Cosa - have you tried it or just passing on what you've heard?
I started on 5/3/1in march and love it, after 5 months from no weight training of any serious nature,
Learning squat, military and dead lifts from scratch using ripptoes techniques, and lost 10kg weight, factor in adding muscle mass, that's a fair bit of fat.
BP 1.69
DL 2.46
MP 1.05
SQ 1.97
I'd recommend 5/3/1 to anyone that wants to progress easily. I was stuck at 1.08 on bench before starting also.
Edited by jangles
Is that a 1rm?
Yes. Tried for 120, but could only get it half way back up...stayed there for 10 seconds before I called the spotter haha. I'm very non-linear on bench - in the same session I could push out 2 x 110 or 7-8 x 100. I just get to a weight where the muscles say "that's enough" and you can't cheat your way into another rep on bench...or conjure more strength from other muscles...
That would of been a long 10seconds!
Have you considered reverse pyramid style training?
That's funny cause I wasn't sure how to write it :P
It's a "nope I haven't considered that type of training", but feel free to suggest, elaborate and enlighten.
Awesome compliment! How has it been going for you anyway? Feel free to PM :)
hahaha no worries mate it's the truth :)
In preparation for an 11 night pacific islands cruise I've got Tuesday week, I cleaned the shit out of my diet and have cut back a bit. Dropped a little over 2kg now sitting on 75.5kg. I've done a 140kg deadlift for 1 rep just to see if I still had it in me, and it was f**king easy days! Sure I could pump 2x bodyweight no worries, but no point just now. Otherwise I'm still gaining strength while dropping fat, which according to Markos doesn't make sense :P very slow gains though, very slow. Getting pretty cut, so happy at the moment. I'll provide a proper update with pics in my thread next weekend ;)
basically you warm up to 60-80% of your top set,
Have a 3-5min rest, whatever suits,
Then punch out your top set using all your energy, recover.
Reduce weight 10-15%, do two more reps than last set. Rest
allows you to get your max out whilst in a deficit.
I've done this, overlaying 5/3/1. Works a treat for me.
Edited by jangles
    • he bridged the 2 pipes together in 2 spots. Making a H pipe. i'll get a photo and post it tomorrow
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
