Trozzle,
If you head over to IIFYM.COM it has a TDEE calculator that makes it easy to work out cals.
Yours would be around 200P 370C 90F at a guess on training days.
But for what goal? Maintenance? Gaining?
That'll be maintenance, but that's why you head over and punch in your details!
Usually lean meats are around:
100g = 30gP
Cup of rice ~50g C
350g potato ~ 50gC
That's the basis I use anyway.
I don't count condiments usually
Edited by jangles
I'm only just realising how little carbohydrates are in things like steamed veggies lol...no wonder I'm at such a shortage even though I'm eating plenty :whistling: f**k this nutrition shit
Eat some pasta you skinny bastard.
Yeah it's easy as to hit protein, carbs are killer.
really only peas, corn and carrots in the normal vege types. Depends how many of course.
Takes a LOT!
Cereal is easy to eat. Takes a lot to get the grams up still though. Find suitable large bowl, keep filling until target carbs met.
lol fark alright easy on! :P
Takes a LOT!
Yeah cereals are good, it's just annoying to see how loaded with sugar even the apparently "healthy" ones are. Got myself a shitload of muesli though, plenty of fruit all through it n shit. Gonna snack the hell out of that at work.
Eat a shit tonne of bread/bagels, they have few carbs in them...
This as well.
Troy, if you want a good all rounder...try toasted tuna sandwiches/melts. Carbs + protein galore.
Also, that fruit muesli will probably have a decent amount of sugar in it
haha yeah it does, though less than the stupid sultana bran I'd usually eat if I had cereals. I don't eat fruit through the rest of the day like I see some people doing excessively, so no sugar intake there for me. Nor do I have sugar in my coffee(s).
woah, you guys are getting too far into this 'in my personal opinion', or more so, over complicating it.
I just put food into 3 groups.
Good food, okay food, bad food.
Good food - fruit(eat it all day), steak, chicken, veggies, eggs etc
Okay food - bread, rice pasta, weetbix, yoghurt etc
Bad food - ice-cream, pizza, maccas, chips etc etc
So eat as much good food as you want when you want. Eat the okay food when you want, just depends on goals and most importantly body type.
Bad foods, eat at own risk. With my body type i eat this shit everyday, but i know i can, so i don't care.
None of us are competing bodybuilders, no need to overcomplicate things.
Remember this is my opinion ;)
IMO I think that's what complicates it.
A carb is a carb. Be it grains or sugar. Obviously eating sugar all the time won't be the best way but if you eat 1000 cals from your good food category or 1000 cals from your bad food category it's still 1000 cals.
Fruit is just a ball of sugar.
Hit your macro targets and it won't matter where they come from, unless you're trying to compete.
Apart from the fact I'm obviously not hitting my carb macro target and way overshooting my protein target, this is exactly what I'm getting at - you guys have overcomplicated something that's obviously working for me anyway :P
It's not complicated, it's the basics.
that little carbs you must nearly have bunny ears by now haha.
Imagine if youd hit them earlier, you could be leaner, bigger, stronger quicker.
saved money
Macros are easy, knowing them allows you to eat anything you want really.
I hadnt been to the gym in 3 days and had KFC and maccas. But I'm still in a deficit leading up to my holidays
Edited by jangles
saved money
You've been following IIFYM a little too literally I think...Thanks for the advice, but I'll stick with what I have been doing and am now doing, even if I AM doing it wrong.
I don't follow iifym, just used it's calculators.
I'm not sure how you can do something too literally though. Cals in vs cals out.
it's only my take on things and suggestions. Everyone has their own ways. There's no right or wrong way about it.
Edited by jangles
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
