the PCYC has a court upstairs so I'll go shoot hoops for 15mins to warm up... then squaaaats;)
put a hoop up recently... on the front of the car port... haven't had a hoop since I was living at home many moons ago... daylight savings is awesome, get home from work and have enough daylight to shoot around
having a basketball game the day after a powerlifting comp doesn't work particularly well... feels like your in slow motion... epic lower back pump
Bought myself a close grip handle for T-bar rows since the one my gym has for the seated row is a ghey piece of shit without a recession to sit the bar in between the handles. Turned up yesterday (I think it was overnight delivery lol). f**k I love T-bar rows, back is really feeling it all the way through my traps and lats right now.
One of the many great purchases out there to take to the gym with me. For $35 it's not bad.
I find T bar rows the best back exercise for the mid back... especially with the little v handle... better than barbell rows IMHO
I always use the smaller 10kg plates for this... makes for more loading/unloading but you can get a better ROM as the bigger plates hit you in the chest before you can really get your elbows up and back
you can also use that handle on the pull up bar... lean back a bit and pull your chest up the the handle etc
This post. Spot on. Love it.
I can get a better contraction with my hands in that position... I feel it works the rhomboids better... as long as your not too upright and using lots of body english to swing the weight up (then it becomes a half shrug movement)
I also like Pendlay rows and one arm dumbbell rows... The Pendlay's I like to go heavy and not too strict on form... T bar and dumbbell rows done strictly with a pause at the top
barbell rows into my stomach, navel region... T bar rows into my sternum area
reverse flyes for rear delts... powercleans for traps... pull ups for lats... Deadlifts for all of it
love training back lol
Ok so i'm going to try Rippetoe's starting strength for the first time tonight. I'll be working at it for 6-8 weeks over this summer as I now have down time to sleep and eat a bit better now that my CIT course is finished.
Lets see what sort of strength gains I can make...
Got Milk?
PS - there isn't enough deadlifting in his program...
I know he goes on about it needing more recovery time etc etc.
But I got stuck on a shit weight for a long time doing it his way.
added more volume for deadlifts and shot up many kilos for it.
Edited by TTT
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
