^ only for the people who know nothing...but I'm so tempted to write/stick a note on his ad(s) - please show me the evidence that you can achieve site-specific fat loss with exercise and diet changes?
You're not seeing the subjective definition...spot could refer to shedding fat on the spot at the gym. Also the possibility it refers to one big spot...*draws circle around person*
a real BIG man was struggling at the gym today, could see his motivation wasnt there.
went up to him and simply said "think of your body as a toilet roll. work hard and you'll strip off a square each time. you might not see it, but in time the toilet roll becomes depleted; the layers removed." could see him go up a notch after that.
great session today :)
  On 29/11/2012 at 4:18 AM, Birds said:
Love hot days like today in the gym - nothing but the dedicated in there.
Damn straight. I remember last summer rocking up to the gym when the aircon wasn't working and seeing that it was 36 degrees inside. Place was nearly deserted. f**k yeah nobody in my squat rack!
good video this, only watched the first part out of three.
http://www.youtube.com/watch?v=i1pjY1mDAa8
Seems like a real cool kind of guy as well in this.
Edited by -FIGJAM-
Ripptoe is boss for techniques. Look into wendlers 531 program for strength gains. It doesn't seem like much, but after 6 months and you're still gaining its rewarding.
If you look for 20kg gains in a month you'll probably end up at the same place, lifting same sort of weights with no progress.
Consistency is key imo.
Agree^
Seems to be that oh-so-human-nature trait of wanting everything as fast as possible and then getting it as slow as possible. If you're not using 1.25kg plates because you think it's a pointless increase, you crazy.
I give no f**ks what it looks like squatting with them on the ends of the bar...I've been making my steady increases of 2.5kg a week without dropping reps to accommodate the new weight. Come at me plateau!
what's everyone's thoughts on Albuterex used with Alcar (Acetyl-L-carnitine)
I've gone up 3% in body fat, since August but still the same muscle mass and if anything have increased my workouts, diet is healthy etc
Feel like I need something exta but dont know what.
thanks
Lol i'm sorry but I can't watch a Kai Greene vid after the whole grapefruit thing. The guy is an odd fella.
Wendlers 5/3/1 program looks alright, pretty common sense based, and it's something I might look at doing down the track. No way am I going from starting strength to that though lol... Same lifts for low reps would drive me insane of boredom.
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
