I would definently say you need carbs.
Your brain needs glucose.
If you are trying to build muscle/put on size I would think you'd need a reasonably large amount of complex carbs along with lots of protein.
I don't like following diets and it's pretty surprising how much healthy food you can eat without getting fat when you lift 4+ times a week.
Your body doesn't need carbohydrates to function, but it does need them to function efficiently.
If you have to abstain from carbohydrates in your diet, then you are eating the wrong carbs.
Dare i say it again, but if you eat properly, you will never have to go on a diet.
This... f**k low carb diets
For those that have asked about Albuterex previously:
http://www.tga.gov.au/safety/alerts-medicine-albuterex-xtreme-121221.htm
Looks like it might have been a lot more effectively than previously speculated LOL
no it's not a measurable difference, you can burn up to an extra 60 calories I believe
Actually you are mistaken. There is actually no such thing as negative calorie foods, despite what the health gurus like to say. Generally speaking, about 5 to 15% of our daily caloric intake is wasted on digestion. The highest burning substance is protein at about 20 to 25%. That means that if you eat 100 calories worth of protein, it will take 20 to 25 calories to digest it.
Celery on the other hand has very little nutritional value, and contains cellulose (which the body can't digest), so it takes very little energy to digest (and chewing it takes bugger all energy either, something like 10 to 15 calories per hour). So if you eat a stalk of celery (containing about 8 calories), you will only burn off 1 or 2 of those calories in the process,
http://www.tga.gov.a...reme-121221.htm
Chestbrah won't be happy.
Dam and I was going to give alburtrex a go........
In the states at the moment, haven't hit the gym for 2-3 weeks. Feeling the effects already some good and others not so much. Shit food is doing my head in as well. The yanks need some lessons on how to cook eggs and bacon
yeah I want to get to the gym as well. Far too much good food and wine with little exercise.
But..... bloody well shagged my left knee joint after it collapsed on me, twice. Hopefully just a cruciate strain or small tear, but cant tell at the moment.
Might head in anyway and try some upperbody stuff. Just dont want to stand up much atm.
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
