Troy you muppet.. the deadlift for reps is with 100kg.
and you want to 1.5 times body weight making it 115?
but don't want to hurt yourself?
Please explain
1.5BW was just a suggestion (which for me comes to 109.5kg anyway). It was more to even the playing field. Perhaps work out what ratio of bodyweight the 100kg reps were for Joey and then apply that to everyone.
These vids are from 2007, weighed ~60kg
http://youtu.be/JmvveXH5lrw
Ps. do not deadlift like that ^ I have 2 bulging discs and I'm pretty sure the way I deadlifted back then is what caused them.
it's rare to have someone that can OHP body weight so I doubt you'll get people even able to do a single.
I certainly can't.
Pffttt...What is this ' I certainly can't ' rubbish.... you can and will ha ha..... People just need to add this as a goal.
If you are able to put time into bench press you will do well to train to press your body weight for reps.
Besides if you can train yourself to this goal , my bet is your bench will increase.
Not a proper strict press anyway
Sit down an do it, stops punters from hurting themselves initially before they do the standing version. Standing strict is just without the leg drive but, that is also a good version of the press worth throwing into training.
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
