Yeah I got myself some chalk the other day. It's better than I could have ever imagined, even in my wildest dreams lol. It actually made holding on to the bar less effort entirely, even on the FIRST REP. Before there was any moisture at all. Amazing. Never doing deadlifts again without it.
It's not light in that the potential for injury is very much there should you use bad form, which is why I brought up what I lift for that exercise in the first place. It's like a 100kg deadlift - nothing in the scheme of lifting and what people are capable of, but you can still do a lot of damage if your form is out.
Thats true. Bad form is always well bad... However, if you know how to lift even good form isn't a replacement for strength in the supporting muscles.
The excellent form can turn to bad form very suddenly when a supporting muscle gives out.
So approaching heavy lifts is not only about good form and technique but also conditioning for the lift. Lifting is never really 'safe' , just relatively.
So you can do the lifts with legs locked out quite safely with the supporting muscles in place and some form. I just did some 105kg-ish overhead presses today, I have a vid in my training log. My first standing ones in many years. Shows the fatigue of my last set , the form suffered a little but, it was a walk in the park for my back / legs / shoulder girdle.
lol
I look forward to hearing how you jizzed your pants when you actually get a chance to deadlift using chalk and a texas deadlift bar on a deadlift platform.
lol
hahaha well my 14 reps @ 110kg was with chalk :P
Need to improve on my cardio.
Me too I think. Was playing bball yesterday and was pretty much dead after 30 minutes. Was totally cool launching myself over 8ft fences to get the ball but after running for 10 minutes I'd be dead lying on the ground. Felt so sick it felt like I was going to throw up and ended up napping for a couple of hours to get rid of the headache it caused. Makes me think maybe my CFS hasn't fully been taken care of :(
At least I could jump a fence... that's new!
Edited by JEPPE
Bench finally back to 115kg @ 80kg. Will try for 120 next Monday. Hoping to have a 1RM between 120 and 130 in time for the next novice comp. Even if it shaves 10kg off my gym lift, that should still make for a respectable bench.
I'm sure you could do 120-130 fresh now even, we work fairly hard before we even get to 1RM
Aren't comps just 1RM anyway?
True...but it's much safer to assume your 1RM after a bunch of sets...then you know for sure you can pull it off fresh; maybe even do better :)
You get three attempts in competition, correct?
If you aren't doing pause benching then I'd reccomend switching to that in the time before the comp. You need to pause at the bottom of the rep just touching the chest (not resting heavy on it).If you haven't trained for it you will moving alot less weight at the comp.
Bench rules are:
  • Pause on chest - this means the bar has to be motionless and you'll be given the press command - if you have the bar down on the chest but it's moving around you'll be there till it's still and told to press
  • Bum must be on the bench.
  • feet must be on the floor - GPC, CAPO federations allow you to have your feet so only the toes are on the floor but PA requires your foot to be flat on the floor. If you lift a foot when benching for whatever reason (balance), then it's a failed attempt in any fed
  • Grip can be close or wide - I think there is a rule that it must be inside the outter rings on the bar
  • 3 attempts at each lift - but if you decide on 100kg as your first lift and fail, you can't select a lower weight for your next attempt.
Here is what I try to do for any comp.
Opening lift (sq, b or dl) I chose a weight that I have done a tripple with in the gym already, when fresh.
My second attempt will be my gym 1rm PB that I would have attempted before comp
3rd attempt will be for a new PB.. wether that is 2.5kg more or 5 or 10 will depend on how I felt with my second attempt.
I would suggest doing some paused bench sets before trying it at a comp.
get your training partner to say press when they see the bar is still etc.
The calls for comps (you'll be told this at the comp but anyway..)
For squats.
you will get under the bar, lift it off and get ready to squat (in novice comps you will be walking the bar out, in GPC comps it will be in a monolift wo when you stand up with the bar on your back, they will remove the hooks that hold it and you squat on the spot.), look at the judge and stay still, he/she will yell out "squat"
you squat down, stand up and stand in the locked out starting posittion... Judge will then call "RACK" and you walk the weight back to the stands (or in GPC, they will lower the hooks for you to lower the bar back on to.)
For Bench.
Lay down, set up however you want, give the person handing the bar to you a nod to say ok to lift off.
Once it's lifted out and you are ready to bench, you lower the bar (no call here in any fed other than PA), pause on the chest, judge will call "PRESS", you press it up and hold at the top in locked out possition and the Judge will call "RACK" and you move the bar back to the rack.
For Deads.
Walk up and set up, the judge will be sitting their with their hand up in the air..
Grab the bar and lift it as you want and stand in lock out standing possition.
Judge will call "DOWN"
Lower the weight down in a controlled fashion... basically means don't drop it, but don't waste a heap of energy bringing it down super slow.
There are other things that will cause a failed lift that they will tell you about on the day... hitching, lapping, bar dip and some others.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
