I have an extremely high tolerance to pre-workouts or in general...stimulants etc.
I tried Craze for a while but needed 4-5 scoops to really feel it. This is coming from someone who was using 200mcg of clenbuterol each day and eventually became completely immune to it as well as DMAA. So instead I simply finish work, train than eat some good solid carbs and protein. For almost 2 months I haven't had any supplements whatsoever. Old school is the way to go :)
you've definitely changed your opinion then...
Here is a thought to consider. I make some assumptions here so take from it what you will.
How much do you rely on the stimulant pre-workout to give your best effort in physical performance?
If you are saying you don't do as well without one, then you are likely not even close to your limit.
Not trying to sound too harsh here but, It's a mental crutch. You are waiting for some kind of buzz to tell you it's now ok to pick up a weight.
You are the one lifting the weights when you are taking it, not the suppliment. Once you realise that ,you can pocket the money and buy some beer on the weekend with it.
Funnily, we're talking about PWO supps being a waste of money with regards to fitness....so instead you suggest the consumption of alcohol? hahaha :P
Good point. They are both un-related to fitness, except one pretends to be and isn't.
Edited by rev210
Didn't know clen had a pre-workout type effect?
Used wraps for the first time since August last year for squats...
man.. don't miss that pain.
and that was with half arsed wrapping.
good rebound though.
and the tightness gives a nice secure feeling when you look past the burning pain on the back of the knee.. lol
Never if you don't need to.
I've only done a best of 150kg for 3 sets of 5 squats without wraps.
Program had me doing 145 last week and 152.5 this week
so I started using them this week and will keep doing so till the comp in April.
I think you get used to them after a while... just like your hands get used to deadlifts.
I've seen blood on some peoples legs before and lots of bruises.
I had Scott at PTC Brisbane wrap me once leading up to last years Nats.
he goes, how tight do you want them?
I told him to go easy first time since I'm used to wrapping myself.
He goes ok I'll go about 50%
This 50% managed to get 2 extra loops around the knee then when I wrap "tight" at home myself..... It hurt like hell.. lol
And my wraps are the 2 meter ones which are well used Inzer ones.... compared to the 2.5 others use.
Hopefully I'll better my last PB at a slightly lighter bodyweight come April.
Going back on SS until I hit 180kg dl, 140kg squat, 100kg bench. Didn't feel like I was getting anywhere on the other program I was on, progression felt too slow.
I have been on the same program for about a month now, lifts have improved but my biggest issue is the gyms weight. I have to go up with 2.5kg increments rather then the 1.25 that is suggested.
Have plateaued on bench already at 60kg which I am trying to get past. Always sucked at bench for some reason, always get to 60kg and struggle to go up any further.
Weak shoulder girdle muscles is the reason. I can tell you that a good way (other ways get there too) to get your bench max up is the following ;
a) stop doing bench press
b) Start doing work on your shoulder,.scapular and rotator cuff strength and flexibillity.
c) Gradually incorporate strict press movements
d) when you can do your bodyweight on a strict press then you can think about bench press.
e) You are only allowed to 'think' about bench press until someone shows you how to do them properly, then you can 'do' them.
Do something like this and that plateu is going to be history. Also you are going to have much better muscle balance and less risk of injury as the weight goes up.
Edited by rev210
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
