I would never like to use supplements or any other shortcut methods to strengthen my body and shapes. As it could lead to some real damage to our body later in the age, as it start losing skin too early and by using supplements we might end up on wheel chairs at later parts of our lives.
There's no supplement to fix what you have.
I never actually thought my dips were THAT low haha...now you've got me thinking I am going too deep :unsure:
If its not causing you any problems thus far, stick with the way you are doing it.
On a personal note, I can't get much below parallel without it stretching the crap out of the front of my shoulder.
Snakebrah?
Just watched that dip vid, great depth.
God I can't wait to get a rack with a dip station.
I'm still looking for some feedback on the recent vids on my build thread if anyone would care to comment.
Changed some things, no towel on the bench, SLDL instead of DL, and using full weiht on things for demo purposes.
http://www.skylinesaustralia.com/forums/topic/421637-project-squat-dodgerno-more-curling-like-a-broget-ankle-better/page-4
That link for the rack you showed before may not be optimal for dipping for you, who's to say the grip width of the handles won't be too wide for you? The ones on mine are angled so you can place your hands on different parts of it to get the proper dipping width.
Also, if I have a bit of tightness/discomfort/ a twinge in the Thoracumbular Fascia area that seems to be aggravated by exercising, is lower back stuff more likely form or too much weight related?
http://vanessaruns.files.wordpress.com/2010/03/back-muscles.jpg
I'm having my lower back/pelvis worked on as part of physio for my busted ankle, which saw me walking unevenly causing pelvis rotation, and am doing light back/shoulder stuff as part of my gym work, but it doesn't seem to want to go away unless I stop all gym work.
I have some specific oblique and inner glute exercises that I've just started doing on the advise of a Myo and a Physio.
I've got form videos in my build thread but the comments tend to be that form is "ok" and that the weight is light and I'm a girl :D Bare in mind that until recently I was squat dodging and doing little to no back/shoulder work.
Anyone else had experience with injuries in that area?
Edited by ActionDan
oh there is a name for that spot.
that is where my pains are.
I try to get tight everywhere around there before lifting.
but clenched, lower back arched, shoulders back and down, lats engaged, big breath in, crush the bar and up it goes.
so I'd say it is a combo of form and weight.
gotta learn to stay tight.
Just watching your vids with squats and deads, and I realise that you are doing light weight to show form, but you don't set up at all.
you get in to position and lift.
As an example of setting up, look for a video of David Tate talking about Bench pressing.
even with an empty bar, it takes him a good minute to setup his position etc.
Your back will hurt less if you setup right and get tight everywhere, then lift.
Think of which body parts are doing most of the work and certain points in the lift.
deadlift starts off with leg drive and then changes to hip pushing through and shoulders locking back.
etc etc.
etc etc.
In the second set of videos, the ones that didn't embed, that was actually at training weight, yes only 50kg. I've squatted and SLDL more in the past, up to about 80kg, but have never had this sort of back discomfort. The real pain, especially squat, is getting the weight up and over on to the shoulders which is why I will buy a rack.
I'll try and pay more attention to tightening up things before going through the motions on Wednesday. The weird thing is, I do not feel notable discomfort during the motions, only the next day - aside from the shoulder twinge I had but that seems to be OK now.
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
