Yeah gonna suffer DOMS hard, but should be worth it. If I find the load too taxing I'll cut down. I just wanna exercise as much as I can to make up for lack of upper body movements. Need to keep the calories off.
I don't think you need to worry about this, especially next week.
If you injured yourself badly I'd be reluctant to lean on it without at least giving it a weeks rest.
Better yet, see your chosen therapist and see what they say.
Seems like you're busy enough squatting anyway :)
Tried an empty bench bar in the same session and it didn't present any pain...I could be back to upper body sooner than I thought :)
Playing it safe though. Do we think it's worth doing movements like bench with an empty bar for rehab? Or just wait until completely healed and get back into the weights?
Feeling pain or not, isn't a good indicator with the rotator for recovery. The pain is there when the swelling goes up and that can take a few minutes to an hour before you start hurting. Hence your bench blew it out but, you didn't feel it till later on a relatively light excersise. You can have deterioration in the muscle without feeling it as pain, so be carefull.
testing very carefully the 'weakness' is the way to go. You want the strength to be at least that of the unijured side.
Bench press isn't a rehab movement for this injury. Don't bother with it. Even the empty bar bench doesn't address anything related and you just look like a feeb doing it.
Copy/paste from my build thread as questions get answered quicker in here.
For some reason, my back is worse than it's been so I either did something Friday night or sleeping in shit hospital chairs/not sleeping is giving me grief (Kate has been in pre-labour for the last 3 days so we've been in and out and not sleeping very much). No gym on Monday as a result so I've had a good 3-4 days off.
Not even a stretch is helping me and it's pinching randomly when I'm not doing much.
I've noticed, with squats, that if I go below parallel my body tends to lean forward at the bottom of the motion which I'm wondering if that's causing some kind of cantilever effect on my lower back as I come back up. Or is some form of forward tilt at the bottom of the motion normal/acceptable?
Extra info: A podiatrist friend came over on sunday and did some tests, said my legs are 1.5cm different lengths, specifically from the waist down so nothing from the back as she measured that too. I put orthotics back in my shoes (just off the shelf ones) on her advice on Sunday but I "think" my back was already playing up before that.
Edited by ActionDan
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
