don't you get all of the BCAAs that you need from sources of protein like food and shakes?
Pretty much lol. Only advantage I could see with getting a pure-BCAA for intraworkout supplement is if you tend to train a little longer than you should, so consuming them part way through your session could assist with repair and avoiding excessive catabolism.
I'd have actually thought the majority of them would be prohibited from events, Markos?
We dont compete in a drug tested Fed, so no cheats. ASADA have a few of them banned, I cant tell you which ones as it is of no interest to me. It was when I was working with the Dolphins, but no longer.
The reason we cant take them interstate or overseas is that they are an illegal substance in some countries, but I suppose we can always drive interstate
My new bar and bench turned up, will assemble bench today but it doesn't look too bad.
I noticed the bar has a few marks/chips around the where the collars would sit up against if they were screwed up all the way, though they were not sitting there during transport that I can see.
Small marks and seemingly fairly superficial, can anyone think of why this would be an issue? Maybe greater chance of rust or something?
Trying to decide if it's worth pursuing.
Looking at it now I'm thinking they are pretty superficial.
This is the sort of thing I'm talking about, there are more but these ones stand out.
as you can see not big, just don't want it to be a sign of things to come.
Is that one of those cheap bars that weighs 6kg? Years ago the first bar I bought was from Amart AllCrapAndOverPricedSportsGearGuaranteed, and it bent...in half with 120kg on it. Hope it doesn't turn out to be a waste of money Dan.
LoL me too.
It weighs a tiny smidge over 8kg.
I got it from world fitness, same place as the York bench. It was about $50.
If its not good ill get a refund and something better, if it survives the warranty period then I got what I paid for I guess.
little side story on weights, back when I had my shop I also sold a bit of sports gear. Had a rep that sold the York fitness gear, as well as other fitness gear in. he was telling me about some of the weights they had gotten in cheap. when weighed there was some variances on the claimed weight vs actual weight. sometimes the difference was substantial. from memory the biggest difference was about 20% on a 20kg weight.
    • I am probably calling this too early but I think I found what part of my problem is. I have a couple of dents that are fairly close to each other and I tried to fix them individually. Recently I put one larger coat across all the dents and sanded it and for the first time ever it's all even except for the edge where the bare metal is, I just need to put some putty there. I'm ordering some better longer blocks that are more flexible. Other good news is that the other repairs on my panel are flat even with the guidecoat. It's these 2 dents which are an absolute c*nt l lol.
    • Murray will have better input, but I'd be going with less filler, and aimed at the low spots mainly, and hence won't need as much sanding, which then means get the guide coat on earlier. That's how I'd do it, BUT, I'm not a pro, I'm a DIY hack who will then get the shits halfway through, and have one spot awesomely repaired, and the other spots look like a 3 year old was left unsupervised with workshop tools...
    • Where is the most common place to locate it? Disappointing that Garrett won’t make a fitting for it since they know everyone will use it
    • A HICAS fault really should not cause the engine to go into limp mode. These cars are so old that the systems barely talk to one another. The thump might be the lockoff solenoid valve for the HICAS (the safety valve) getting closed, to lock the rear wheels "straight". I say "straight", because when my HICAS used to shit itself before I took off and nuked it from orbit, it would lock up with the rear wheels wildy non-straight and you'd need 45° of steering wheel to drive straight. Take off and nuke it from orbit. First step is to pull the smaller of the two plugs out of the HICAS CU. See if it stops misbehaving. You can also (whilst leaving it plugged in) try to get the HICAS CU into diagnostic mode by doing the pedal dance, or by connecting a CONSULT capable diagnostic reader into the car and seeing what it has to say for itself. Can't do either of these with it unplugged though. 1st gen HICAS is a ballache. I would do a complete delete. I did do a complete delete.
