Try it in water and let us know what you think....
I've had 7 days off straight! That's the longest break I have had 18months!!!
What about you guys, do you take periodic breaks? If so is there a pattern to it or just when you feel like it? How long?
Mix what in water? Who are you talking too lol
As for breaks, I'm a serial break avoider and have had to learn it's ok to skip a session.
I try and listen to my body. If I've had a big weekend on the car and haven't recovered from Fridays session I might take Monday off.
Edited by ActionDan
This is me. I went to the gym a few months ago after being in hospital and high on painkillers because I couldn't miss it :/
In the 5 1/2 years I've had PTC I've never had to pay for it, Ironedge give me boxes of the stuff, thats why I was unaware of its price.
It does last a very long time, so I suppose $30 a year is pretty cheap
I'd been considering using chalk lately, as our gym is often farking humid during the cooler weather - I used to use gloves but seem to get a better grip on things bare handed.
Got my Bulk Nutrients WPI yesterday, mixes with a lot less water than what I'm used to, but a lot more watery than my ON stuff. Tastes pretty good though, and certainly a lot cheaper than the bro science claiming, heavily marketed alternatives.
    • And no, this was not posted on April fools. https://www.theautopian.com/bmw-wants-you-to-drive-with-an-air-compressor-attached-to-your-wheel/ What happens when it's not attached properly and flies off into somebody's head?
    • https://sci-hub.se/https://doi.org/10.4271/2005-01-3825 Heat causes positive pressure in the tank, a slight vacuum in the tank is normally caused by evap purge during normal driving. If the tank is cooled it can also cause a vacuum that pulls air into the system. The linked paper is quite interesting to learn the state of the art for evap fuel control, modern systems the tank is 100% sealed and the tank is reinforced to handle higher than normal pressure/vacuum. It only opens the vent/charcoal canister when you press the button to open the refuel door or when the engine is running. After some reading of systems like the W220 S-Class there's a check valve on the tank vent, but the primary reason it's there is because otherwise the intake manifold would be pulling vacuum on the tank: https://w220.wiki/EVAP_system   There might be limited vacuum relief via the charcoal canister, but I don't know how sensitive the check valve is.
    • me too wasnt real happy and cost me a penny or 2 to replace
