TTT: No comment on how you last went or numbers?
Lashed out and bought myself a dipping belt.
My tracksuit pants and jacket topped out at 20kg of pocket space lol
Good job Troy!
Edited by ActionDan
sq 192.5
b 100
dl 210
at 86kg at GPC states around Easter.
best bench in a 3 lift comp was 110 @ 92kg and 115 @93kg in a bench only comp.
Best deadlift in a 3 lift comp was 220 @ 92kg and 222.5 @ 94kg in a deadlift only comp.
Next 3 lift comp is in 3.5 weeks. Don't think I'll do much better. Will not be using wraps for squats... Should still be around 85-87kg
Nice squat and DL.
Do you have bad shoulders or something or just not into bench?
I dunno what my 1RM is but I can rep 110 now so you'd have to think 1 rep would be a bit better.
How long did it take you to get to those squat and DL numbers and how tall are you?
one of my asian mates from high school used to always be pretty skinny, now i'm guessing he's like 80-83kg competing for australia and just did 235/187.5/117.5 and posted some vids up on facebook crazy strong shocked me that it was him - only 23 too and hasn't trained long :\
/csb
I'm keen to get into more / increase deadlifts now
Edited by UNR33L
Right scap has ongoing problems. Both shoulders sound like ratchets moving in any direction. Tennis and golfers elbow in both elbows... So yeah. A few problems with bench.
The first time I tried a squat 1rm I got 150 but failed 155. Before this I had done about 5 years of wannabe bodybuilder type training. Still did squats but it was once a week and it was 3 sets of 10 and was superset with leg press or ham curls.
Best dead lift during those days was 180 with straps and it wasn't a proper deadlier. It was a start from Waist height then down, bounce and up... Using straps.
I'm 178cm I think.
Stop doing bench for 6 months. Do the rehab and you will be much stronger going back in.
Edited by rev210
/csb
Where did he compete for Australia? Those numbers dont seem very impressive at all in regards to competing FOR Australia.
I have an 82kg lifter who competed at Nationals 2 weeks ago, still a Junior at 20yo, so same weight and age group as your mate, and Asian
Martin squatted 245kg, benched 160kg and deadlifted 282.5kg, total was 687.5kg, a GPC Junior WR
Thats 147.5kg more than your mate. Your mates total would have got him 9th place at Nationals in the 82.5kg class
Colin Chan?
74kg class, totalled 540kg, nice, finished 7th at Worlds in Russia for PA
yeah he's my mate, and yeah Russia - I didn't know his weight was just guessing off the top of my head from the far away video footage very proud of the dude!
Edited by UNR33L
I have. It helps to a certain extent. Never 100%. Soon as I get close to where I was...its failboat again
So you have taken 6 months of zero benching? Plus the rehab including cuban press, broomstick shoulder dislocation stretches and the rest?
I got the impression you keep doing bench regardless because ' a comp is comming up...' ha ha....
No bench means you have more time to focus on squat. Why u no squat 200?
Cuban press f**ked my other shoulder.
stuck to doing band rotator stuff along with overhead press which doesn't hurt and actually feels like it has helped some.
Anyway, I don't really care about it much anymore.
No 200 squat because girlyman.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
