Can't find the thread...
Did find this in my travels though, which is a pretty big statement to make
http://ausbb.com/bulk-nutrients/20987-serious-note-bulk-nutrients-our-5-000-challenge.html
2mins work.... for everything else there's Birds.
Thread link: http://ausbb.com/bulk-nutrients/23192-good-bad-ugly-must-read-if-you-buy-wpi-wpc.html
Excerpt from thread:
Ok, now you've got me worried, how can I make sure this isn't happening to me?
This is much easier and cheaper than you think. The following is a list of Nata approved laboratories which can verify your protein products, there would be plenty more.
You simply need to call the laboratory, have a chat about testing powdered whey protein samples, let them know its whey protein testing, fill out their form, send YOUR product in, pay approx. $50 and await the results.
The tests they use will be utilising the Kjeldahl method, this measures total nitrogen content and multiplies it by 6.38 which is the factor used for whey. Note this is exactly the same method used by the manufacturers of raw whey to determine their protein percentage. This method by an approved lab is beyond question and they will all guarantee accuracy within a very small range.
If the lab ask, you are wanting an “as is” tested protein, with the moisture present, as this is the same value that all labelling is based on.
DTS Food Laboratories Vic
Phone: (03) 8371 7600
Fax: (03) 9372 2013
Email:[email protected]
NMI Sydney
105 Delhi Road, North Ryde, NSW 2113
(PO Box 138, North Ryde, NSW 1670)
T: +61 2 9449 0111
F: +61 2 9449 0297
NMI Melbourne
1/153 Bertie Street, Port Melbourne, VIC 3207
T: +61 3 9644 4888
F: +61 3 9644 4999
NMI Perth
ARRC, 26 Dick Perry Avenue, Kensington, WA 6151
(PO Box 1246, Bentley DC, WA 6983)
T: +61 8 9368 8400
F: +61 8 9368 8499
EML CONSULTING SERVICES Brisbane
Registrant ID: ABN 39081082555
Street 1/148 Tennyson Memorial Avenue, Tennyson
Phone: (07) 3848 3622
Email: [email protected]
Website: www.emlqld.com.au
I think I need to make a few changes to my diet and routine.
In the mornings I'm now clocking in at 87-88kg which is getting plump for me at 6ft, I'm a lighter build guy.
I realise that doing leg work will have added some weight but I've gone up a pants size (now 92R - 36" wiast).
The weird thing is, if I tense up I still have a reasonable 6pack and you can see some ribbage and oblique shapes on the side. The extra "padding" seems to be in the lowest part of the abdomen around the hip bones where you'd get love handles and in my arse.
I'm going to try and get in an extra walk each day (as I can't run AND gym at the moment, ankle will not tolerate it) and remove some sugar and carbs from my diet and keep check on portion size. I'm not talking big weight loss or anything but 85-86 is probably where I should be.
I need an accurate way to know what my BF % is or a good idea on if some of the the weight gain is legit or just fat.
Edited by ActionDan
That's exactly the post I saw ages ago, good work digging it up Dan!
I'd love to respond to your last post as well, but just sat down at desk and brain is FAR from functioning correctly after dealing with Canberra's useless f**khead drivers in the rain on the way in lol
I had MAD problems with my forearms back in the days, it's kind of like an extreme RSI.
Strain will be from things like DLs, rows with heavy weight, weighted chins etc, anything were lots of load is transferred along those tendons.
I am quite tentative with injuries like that now, such that I'll skip a session to recover as I've been burned before.
That's a call for you and your trainer and it depends on how you feel and what you're going to do this session.
I am old and easily frightened now after "training through" everything when I was younger.
I should add: When I'm unsure I'll warm up and get started and just gauge it, pull the pin if need be or do half the sets/cut out problem exercises etc.
Lots of options.
Edited by ActionDan
My forearms are the first part to give out from horrid pump and cramping when doing pull exercises....though recently I had something similar to what you're describing for a day or two as a result of being lazy with light bench press and allowing my wrists to bend back under the weight. For me it was just stretching the muscles on the underside of my forearm that caused it.
Alright peeps, send me $10. Put your username as a reference so I can credit you in the research paper...else be an anonymous funder like Batman or that rich guy from Never Say Never with the weird electro shock flight simulator game.
sbirdsey(a)bigpond.net.au
Before doing that, what are we actually sending them?
What does the money entitle us to? how many samples can be sent in etc, where are you getting those or do we need to supply those to you as well?
Why do you need an accurate BF% number?
Are you unahppy with how you feel/look?
Question: If you get a scan will the treatment change?
Answer: No, it will be the same. In your case, diet.
The BF% was more to say, if I was x and I'm now Y and that corresponds to a straight up in crease in my total BW then I know it's all FAT.
But I'd like to think that in the course of getting a touch stronger in some things I've also gained some muscle.
No, the treatment will not change, when I feel a bit cushy I just do a little extra exercise and cut back on some indulgences.
Doesn't mean I don't like to know what the underlying numbers are :)
I'm a little unhappy with some of the extra mass I've acrrued, Kate is probably a little more unhappy, especially with my butt lol but hard to know how much of that is squatting as I was doing 0 at the start of the year, and how much is extra food love.
Edited by ActionDan
I'm guessing you mean in general, unless you are stalking me? lol
So do the glutes not get bigger with squats? Or is it more the hammies and quads (depending on squat version of course) there's definitely been some quad development which I like.
Why can't you be more like Troy and send money without all these legitimate questions.
I'll be sending a sample of BN chocolate as it's one of the most commonly purchased proteins/flavours on here and it's the only one I've got. I based the cost on only sending in one sample. I assume $50 or whatever it costs will only cover one sample.
If it doesn't go ahead or there are any indiscrepancies, I'll just refund your monies through PayPal.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
