If you don't count trivial sugars also, but at the end of the day it adds up to 200g sugar, did you not eat it?
Well in the context I was getting at with the word 'trivial', to hit more than 50g directly from things I consider to contain 'trivial' amounts, you'd be eating a ridiculous amount of food haha. At the end of the day I'm seeing these silly little amounts add up to maybe 50g of protein (and sugars are similar).
The amount of fruit I see some people consuming through the day blows my f**king mind though....I'd hate to think how much sugar they're taking in each day, even in the "healthy" form of fruit.
Just curious anyone on here who has seen results in benching , biceps and triceps for approx 6 months works in gains? Also I have read alot of conflicting views on carb and protein intake per day as well. I am currently 78 kilos and some body building sites say approx 260 grams of protein and 300 grams of carbs. Than other places I have seen tell me 120 grams of protein a day. Any ideas
about 1-1.5g per lb of bodyweight if you're counting. everyone's theories are different though. and so is everyones body. But now I'm just another statistic
Edited by jangles
I've seen results in benching, biceps and triceps in 8 months work in gains :D
Go to iifym.com and use the calculators to find your daily allowances for protein, carbs fibre and fat based on your age/weight/exercise level/what you're trying to achieve.
well its only around 170 if you choose the lower side. Its not much at all really.
average 250g chicken breast = 75-90g protein.
Hmmm that still equals approx 240 grams of protein a day. Damn that's a lot. I tried it last week while I was away training and just with powders I felt so full all the time I had to force it
Edited by jangles
When most these body building sites say to consume x amount of this and that is generally for someone who is all roided up.
I've started to eat to more salmon, swordfish and barramundi 3-4 times a week :)
Sweet potato is really addictive but I end up eating around 100g of carbs from it lol
I was taking in 300g+ and roughly 2500-3000cal per day at 78kg bodyweight and still dropped ~750g of fat per week. For me at least, there's nothing wrong with eating excessive amounts of protein. Worst case scenario is my body just shits it out without absorbing it lol. Winning.
That's about what I consume in sweet potato a day, about 1/4 of daily carbs
Better than a large bowl of pasta which can easily have 200+ grams of carbs based on a huge serving of it!
With excessive protein consumption, my urea levels were high after a blood test as well as liver function values, and that's mainly due to excessive protein that my body doesn't really need. Better to have more than less I say!
Exactly! Especially since something like a big fat steak is super filling and won't trigger cravings like an insulin spike apparently can. And it tastes gooooooooooooood.
That must be served in a mixing bowl.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
