Yeah I do workout at home, and I don't smell that bad, it's more that over time the shirts build up a bit of odor.
Singlets are the go for summer.
Plus I'm thinking of this doubling as my running shirt and in the warmer weather I wear a shirt to protect me from sunburn (milky bar kid).
My 2XU tights give me the confidence to do all the things I want to do, like horseriding and vacuuming and preparing sandwiches, without those embarrassing interruptions from mother nature.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
I don't run. I generally wear them on leg days.
Self massage/massage should be apart of everyone's routine IMO.
Markos two questions.
1) Can you show me what you consider good bent row form.
2) Given the rom issues i'm having with my ankle and how it affects my squat mechanics, do you see issue with me using a 10mm or so board under my heels?
Okay, I'm rowing now, see how I stay down and pull the bar to my belly not my chest, perfect form, I have 140kg on the bar and I'm knocking out 8's
I recommend the heel, but proper footwear (heeled lifting shoe) is much better, around $120
  • Like 1
went to the premiere of Pain and Gain at the local cinema last night, nearly the entire audience was the swole guys from the gym who also lift 5 days a week + the "natty" bodybuilding crew from the other gym. Good movie, was surprised to see compound movements featured a lot, 10/10 lols
I loved pain and gain thought it was an awesome movie
it came out in the US months ago - I chose to wait for it at the cinema here rather than watch a crappy cam version.
weighed myself again, still at the same point as the last 3 weeks or so, given recent diet and training changes I'll check again in a few more weeks!
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
