Here are some ideas ;
* Sucking in your gut to activate the abbs (wrong). Instead stabilise the abs. pull air in (breathe in) and push the gut out
* not using glutes enough
* You are trying to squat too low with the low bar. If you don't have the extra hip flexibillity your back will round.
It will be your hip movement. Squats done right don't bugger up your lower back. Bad form is going to tell you in the lower back.
Also consider hamstrings could be too tight, in turn causing minor pelvic rotation > tight lower back muscles as they try to compensate/counter the pull from your hamstrings. This is almost certainly MY problem with lower back muscle pain.
Possibly, but I'd like to think I'm one of the more active stretchers/foam rollers here but that doesn't necessarily mean I'm being effective with the time spent or that there's not some other underlying issue that stretching doesn't fix.
I've found in the past that I usually have to "reset" which is normally take a week or two off aggravating motions, then begin specific work for the problem areas, it took me a good few years to get my elbow right after it was hammered from all the bro curls but now it's as good as it's ever been, it just takes time (hopefully not that long though as I've learned a lot about how to recovery from these sorts of things).
I'll get there.
Ugh making me open SAU on my farken laptop mate....goddamn.
Also unless it's Epic Meal Time or similar, I could guarantee you I'd be putting up a fight (comparing caloric intake in a sitting - not necessarily volume of food). I've made myself sick a couple of times when I did my silly bulk few months back lol
It's 10 mins long....could you give me a TL;DW rundown? haha 12,000+ calories in what timeframe? The whole day, or one sitting? Going by the thumbnail for the video, looks like there's ridiculous amount of cheese (fat) involved :D and dickloads of pasta/dough/bread.
I could do 12,000cal over a couple of hours with a few loaves of bread, couple of jars of peanut butter, and honey.....who needs protein PFFT!
4 cups of oatmeal with blueberries
1 kg of pasta
1 family / 1" pizza
2 large cheese and ham sandwiches
3 chocolate chip pancakes
3 French toasts
5 egg omelette
3 egg and cheese toasted sandwiches
5 rockstar energy drinks
42 minutes
Shiiiiiit.....hmm, I reckon if I prepared for it (and got really high) I could make quite the dent in that....but definitely not all of it in that timeframe. No f**king way.
And I wouldn't f**king touch those energy drinks. I'd sooner just eat tablespoons of sugar. At least then I wouldn't want to vomit (well, I would....but energy drinks are f**king rancid)
He's a professional eater; number 5 in the world, so I don't expect you to come close to anything he does lol
He did 120 Maccas chicken nuggets in 14 minutes...I get sick after 25.
Rockstar isn't bad, used to drink it in my LAN place days along with onion rings and milo bars.
There's a vid of a guy drinking 24k calories of olive oil. Definitely hit fat macro for the next month
The aftermath of that endeavour would've been unpleasant lol...I believe he mentioned in the video description that he'd been pissing oil out his ass for a few hours hahaha
Calories are easily piled of just eating high fatty shit. The days when I use to maul down a 1kg bag of honey roasted cashews a few times a week and spend most of the time in the toilet due to the extreme fibre punch. Not to mention it...I was a fat f**k
Edited by vspecIInur
    • I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat?
    • Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
    • Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using?  Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go.
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
