ive increased my food intake by adding another 2 meals a day. Still have not noticed the benefits.
guess im still not eating enough
Use bodyfat increases as a good sign. If you start gaining weight, then you're likely above maintenance which is what you want for breaking plateaus. If you're not gaining weight, you're likely just maintaining or still on a deficit.
beach body? my outlook is no one cares if you have abs if you only weigh 70kg.
body has toned up a bit more, but that could be the change in routine. Went all the way to slopville when I was doing 5x5, but now back to higher reps seems to be coming good again.
Also a marked improvement from my reflux issues. Started drinking those Yakult things each night, can now drink milk again with seemingly no issues. Have pushed it to sitting on the lounge at night with a 2 liter bottle of chocolate milk and just swigging it until bed time. No reflux issues during these times and no issue in the morning. Will try for protein shakes again in the future.
Tried using Zantac or going to a doc for pantoprazole? I've been using it for years, hoping that once I ditch the gut, I should be able to stop taking it.
I seem to have gotten my diet in the sweet spot - losing about .5k a week now.
Edited by bozodos
After working off of power poles and constantly moving all day and wanting to sleep at night I bought a product called pre workout by elemental nutrition I find it works well. Doesn't give me a huge hit like mesomorph but gives me good clean energy for my workout and I can take it in late arvo and still sleep well
C4 and Craze both work aight IMO
Got some White Flood for $10 at GNC (down from 99) cos it's expired sep this year. Might give it a go tonight
Pre workouts decent if you're having one of 'those' days I reckon.
Edited by UNR33L
dafaq is 'clean energy'?
on another note, anyone hit the weights on speed or cocaine? I played the best game of soccer on speed one night, so good after the game i was ready for another.
She's been on it for a week now, she is always messaging me about something/wanting reassurance etc so yeah possibly.
Her message 10 minutes ago:
3 months til summer, panicing I havent got my summer body yet...
Thats a challenge for sure.
Takes time to realise that adopting a new way to live is the secret to getting there and staying there. Your friend sounds like they are 'dieting' in the approach to both training and eating. She will fail long term and may even fail short term.
The decision to live differently needs to be embraced. Then changes will be permanent and the body look will be also. Works when the changes are enjoyable and not punishment without reward.
pendlay rows vs conventional bent over rows anyone?
decided to take your advice and skip flat bench the past few days Rev, the right shoulder was feeling better today so did a bit of light bench (cardio day), but it seems to have aggravated it. Since I obviously should give flat bench a miss for a while, what's a good substitute for it? Not having any dramas doing dips or OHP otherwise.
'clean energy' is a term I mainly see being used by supplement selling bros about their new pre workout or "pump enhancer" supplements LOL.
Edited by bozodos
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
