i dont normally take a pre workout simply because I have never noticed a difference in the past when I have taken them.
only gave this one a try as the guy gave me a whole bunch of samples.
didnt read into the marketing. GAT does market a bit like that, but I have read good things about their products.
end of the day it was a sample, I gave it a go and first test was a good one. I have 3 or 4 more samples of it which I will try and report back on.
so these are the claims;
1)SUPER-INTENSIFIED ENERGY*
2)CLINICALLY PROVEN PRO-TESTOSTERONE*
3)REACTIVE HYPEREMIA (MUSCLE PUMPS)*
4)DMAE INFUSED, MIND-IN-THE-MUSCLE FOCUS*
5) ROAD MAP VASODILATION*
What it actually means
1) It's got some calories
2) Doesn't raise testosterone beyond normal or at all in the case of a healthy person (hence not illegal)
3) So what
4) placebo
5) Only applicable if you are lean. If you are a juiced up body builder you have what you need already.
yet another 'short cut' promise that tastes like apples.
3) So what
4) placebo
In my experience with Bulk Nutrients' Cognitone PWO, DMAE is more or less the only thing in it that I notice a very distinct benefit from. It's just another analogue of DMAA I believe, and DMAA gave me a very noticeable increase in mental focus....so I guess I'm saying in my opinion, it's far from a placebo.
Like t-boosters. Most only raise your test by 42%. An increase of well over 200% is needed for any real muscular results
I disagree Tom, please stop spreading unfounded misinformation like this.
They raise it by 48%. Get it right.
  • Like 1
dollar for dollar, injecting test would be much cheaper when actual effects are concerned lol
Step 1 - engage in dat dere sexy time 5 times in one day
Step 2 - go to doc, say you can't get it up, request blood test to analyse t-levels
Step 3 - t-levels come back lower than normal (yeah you knew this would happen; inb4 sabotage)
Step 4 - get prescribed test therapy and reap the reward of dem gainz for cheap
might as well cut to the chase and start pinning.
Speaking of which, do pro powerlifters use gear? Probably a Markos question, not judging, genuinely curious.
In an untested federation? Probably. In any competitive environment where people devote their lifestyle towards a cause, you can be sure people will be doing everything they can to get the best out of themselves and get an edge on competition. People do it in tested environments like the Olympics; I don't see why they wouldn't in a situation where it is legal. I would if it was my sport.
Every 2nd guy (ok maybe 3rd guy) in my gym is on the gear. Most are happy to admit it too, although its pretty obvious on most. That's in an environment where not many care about what you lift.
I can assume in an competitive environment where testing is not as prevalent the use of the stuff would be frequent. You can get it from anyone nowadays and that makes it even more widespread.
Although its a shame and a sign of the times when whenever there is someone who looks well built or lifts big people assume steroid use...
    • Also, at that point if the engine support stand slips I hope you can bench press 200+kg of RB26. Considering the oil pan has to be RTVed on as well which has like a 15 minute working time between the first drop coming out of the tube to fully torqued to spec I would probably never attempt pulling the oil pan unless the engine is on a proper stand.
    • It’s a gtr, has an alloy sump and will not stick to it obviously
    • Just wait until R31s catch the contagion.
    • As you can tell from updates....I haven't had a lot of shed time lately. When I'm on this though, I feel like I'm reliving Neil's last days. Everywhere I go on the car I seem to come across something he was working out. When I went up to his place just after he passed, I noticed he had a RB starter motor in the vice. And sure enough, this was my shed today So, last episode I mentioned the battery had 12.4ish volts but when I turn on the kill switch it drops to 9ish volts. Even with the stater main power removed, same. Matt said above: And yep, when I removed the solenoid power from the starter, the voltage jumped from 9 back to 11.7ish. Thus my testing the spare starter this arvo. Spare is good to go, just need to throw it in tomorrow. I'm not convinced that is the only issue as the voltage still drops from 12.4 to 11.7 when I turn the kill switch on, but first things first
