I'm assuming if you're doing 170 for reps then it's not really close to your max effort. Maybe that was his point?
Either way, people need to learn to stfu and pull their heads in.
Max effort need not be a 1RM, my friend. It can be the last rep in a set. It can be the last set of an exercise where you are already fatigued to the shit.
I reckon it is. Minor things annoy me but rarely will a gym be perfect for what you want and by the sounds of it I have things better than most.
For the first time lastnight, I had someone approach me about my deadlift form. He's a membership consultant there and he approached me saying "I...I gotta say something man", shaking his head a bit. I said "What?". He says "You're going to end up injuring yourself, your back is arching when you deadlift." I was doing 170kg for reps, so I explained to him that when you're pushing close to your max effort, form will never be perfect. He says "So you don't think form is important?". I reply "No, don't put words in my mouth; form is very important, but if your form is absolutely 100% when lifting with maximum exertion, it likely is not your max effort. I've never had an injury from deadlifts and I could show you an 82kg lifter who can pull 290kg without injury and his form won't be "perfect". I appreciate your concern, but I disagree with your logic". He said "Alright, I'll leave it be, but..." and laughed to himself.
Next minute he's doing some cable exercise and I hear him complaining to his training partner about his back hurting..,wtf? Should have told him to lift the 170kg I doubt he could have even done one of them lol
haha was at the gym yesterday with John and he took out his headphones only to hear the dude talking shit about this same story still :\
on the cables with his mate standing around brah :P
he does have a decent physique at least, better than being told off by one of the skinny kent PTs
Edited by UNR33L
at least the guy was showing concern for your safety instead of just potentially letting yourself get into snap city i guess.
Yes which is why I'm always polite if I disagree with advice. Have had people tell me I'm lifting too heavy on lat pulldown etc. It's tough not to assume they're saying it because they lift significantly less and it's their way of dealing with the dissonance that someone smaller than them can lift more. So I usually give benefit of the doubt.
Haha true. His physique isn't that good, he's just 5 ft tall and looks wider than he is. Dude can't bench more than 3 of his own bodyweight, which is one of the reasons I didn't listen to him.
Another is that I've seen him rock up to the gym on a motorbike wearing no safety gear, save for a helmet. And Jon overheard him saying he doesn't deadlift because a motorbike accident prevents him from doing so. Obviously knows how to take care of a back.
Another is that I've seen him rock up to the gym on a motorbike wearing no safety gear, save for a helmet. And John overheard him saying he doesn't deadlift because a motorbike accident prevents him from doing so...
So it's quite clear this guy suffers from extreme ignorance lol
So my friend at the gym got told off straight away tonight for using too many plates on the leg press...
He's thinking of driving to Perth (4 hrs there and back) every night to go to Musclepit.
However there's a guy in our town who is looking at starting a powerlifting gym, and this guy wants to go there obviously. I was asked tonight if Id be interested in joining once it's up and running.
F*** a four hour trip each night. I'd buy weights to use at home.
What. The. f**k
im expecting this in the next month or so
6 plates off being able to use all the 20kg plates.....
How many plates is this? lol
If there's one thing I HATE about leg press, it's having to load 16+ 20kg plates onto the f**ker, then back off again when I'm done. Use more energy just setting it up than doing the movement!! haha
What. The. f**k
Haha I'm up to 4 20kg plates on each side...
The guys usually help me put them away though ha
That's more than I see most guys doing :cheers: lol
Yeah I've only just got back into doing squats again since ditching them at the beginning of the year or thereabouts. Much more effective, and as you said saves a lot of time loading plates lol
Yeah I do squats and leg press. It's annoying when I fail on squats though because I have to take all the plates off and then back on :/
Leg press is the worst. They should just make one with some sort of quick change pin setup and have a decent amount of weight on it. I used to load 36 20kg plates on and off , at least that gym had plenty of plates and didn't care.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
