I was trying to go ATG as in calves touching hammys, basically as low as I can go, I find that easier than stopping half way down or a bit below parralell which feels like it would be a heap of pressure on the knees.
Not yet, considering it though. Current physio has me doing nerve glide/mobility exercises but after paying close attention during stretching etc I feel as though it's coming from the lower back.
been to a chiropractor?
my little brother had a back issue when he was younger, turned out his hip was out of place slightly resulting in one leg being longer then the other.
My legs are out by around 3cm every time I get trigger point :(
as low as you can go and as low as you can go with correct technique differ vastly. going ATG and compromising form isn't a good thing.
Even though you stretch etc. daily, do you feel you're making any significant progress? Maybe you need to review what you're doing if it isn't effective?
Buy starting strength or something that explains technique in depth, that way you can refer to it whenever you're in doubt to coach yourself.
I'm not sure if this will answer your question Dan, but I think these videos are worth a watch anyway. I watched them last night as I'm having an issue with my knee bending in during squats. It's a five part series called 'So you think you can squat' Here's a link to the first one
Easier to just go and see Matt again. All I need to know is if the butt should be rounding in under/tucking under naturally or whether that should be avoided.
I reckon that's a good idea.
I dont think It's natural to the squat, you're not squatting any lower, you're just pushing your arse down. That's my guess. I'll let someone in the know answer.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
