What do you mean if you were skinny?
In high school you'd have been a rake lol
Now you're a fatter rake?
Lunch time! DING DING DING
EDIT: Oh I agree also, people taking offense to mums is stupid, Kate is kg or two heavier now than she was pre-pregnancy - boobs - and people are on at her about what diet she used
None. I kept eating healthy and I walk every day (until she can get back to running)
It's not rocket surgery people.
Edited by ActionDan
I'd agree with that, Girls/Guys different views that is.
I've already got a missus, so I'd honestly say I care more about how other guys perceive me. In that, I'd rather look a bit bigger and more intimidating so people might be less likely to try shit.
You've got a bit more height which makes up for that though, us short guys have to rely on width instead :D
6ft is hardly short lol. But yeah agreed. There is ego to be had from impressing guys; it need not be sexual. However...if you can impress girls, that can be another way to impress guys...or make them hater jealous dream boats!
Anyway, the important thing here is...we deadlift.
lol in year 10 all I did was bicep curls, so I had a mean set of bis exacerbated by a lack of muscle everywhere else. And I quote "you look like you've sewn tennis balls into your arms".
Its definitely personal preference in terms of what size is desirable, but im 6'1 and 90kg with about 12-15% bf I would say, Im not happy with my size yet.
I have been lifting for 2 yrs (the first 6 months were pretty much wasted by not knowing what I was doing) when I started I was like 75kg. If I think back to what I looked like a 80kg I definitely wouldnt be content with that. You still look super skinny at that weight and height.
Edited by Mitcho_7
If I was to cut id probably only be like 85kg or a little less, but my abs are still somewhat visible as I am now and I see no point in cutting when im still trying to get bigger and bit stronger.
Im not really a selfie person sorry birds...
Hahaha if you've got it, flaunt it figgy :P
You look good Birds. What do you squat now and what did you start at?
Cheers dude. My volume sets are around 80-90kg ATG. 1RM after that is usually 110. Also do 5-7 second pause squats after that; between 80-90kg. When I first started ATG squatting, I was pretty tired after a set of 40kg x 10! So much harder than parallel.
In all honesty I'd like my squat 1RM to be higher...just to match my bench and deads...but I'm pretty happy as long as the legs are growing, and they are. Also have a couple of leg niglets that I'd like to sort out with a break from gym and then start proper 1RM training for the squat.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
