Yeah, the glances your mum must throw at you when you come home with one, I can only imagine.
Probs get hi5's from Dad though?
A mate brought a stripper home to his family once. His dad did hi five him lol. Silly prick fell in love and was devastated when she rooted around on him later on in the piece. In all honesty what did he expect?
What do your weights, sets and reps look like for it? You know the rule...increase one of them!
47.5, was 3x10 now 3x8. Having trouble on the last set getting all of the reps out, but I have also changed from a fixed to an olympic barbell.
That change from fixed to Olympic is a strange one...but moreso the other way around when you are used to bearings spinning the weight around for you.
If I can recommend, maybe try a warm up of 30kg x 10, 47.5 x 10 and then 50 of however many reps you can muster? Or add another set of 47.5 into your existing sets.
opinions on how to improve overhead press and other pushing movements?
do external rotation movements, like cuban press. There are a few ways to approach it. Rows help. If you have a good muscle strength balance then the shoulder is more powerfull by virtue of stabillity.
From experience Not good. Could be an injury , unless the rest of the workout looks like it's doing the same thing. Strain will be to the rotator cuff. The lack of stabillity loses muscle power in the lift and causes early fatigue . Get someone to press a thumb on the muscles in the area firmly . If you can find a few knots then give pressing a break and do some external rotation work for a week or two. You don't 'feel' the rotator cuff till it's inflamed to the point of causing the tendon in the shoulder socket to get impinged.
Quick question. What do dips work? I know if I lean forward it works the chest but if I stay straight does it work the back ?
Tri's, of at least that is what I use for my tri exercise.
4 x 10 of weighted dips seem to work well for me after bench and inc DB presses.
Well I notice that bench is a struggle as well, I had someone suggest that I use the barbell from a rack rather than cleaning it from the floor for OHP, but I thought that was the 'correct' way to do the movement. I think you may be onto something there Rev - I've noticed it's always my shoulders that feel sorest immediately following training.
I do 3x8 bent over rows in my routine already, or are you talking about upright rows?
Birds: fixed BB don't allow for the incremental progression that using 1.25 plates on the barbell does.
I'll do the external rotation movements for a week like suggested then try the Birds approach and post up how I go.
Edited by bozodos
Bent rows are good . Upright are bad for the shoulders and you don't need them.
Cuban press and a few other external rotation movements are what will be usefull.
Also work on mobility of the shoulders and thorasic spine. There are some tests you can do to determine what your starting point is like.
I like this, lol
I knew that doing upright past the nipples was bad, but not in general.
So just a week of doing these assistance movements in place of bench and OHP then try again Rev? I think that I have fairly good mobility of the thoracic spine - I just did this test
and could extend both arms all the way back easily.
I did this movement to test shoulder mobility with sliding one hand up from the bottom of the back and the other from the top - my hands were ~7.5cm and 10cm apart which suggest poor mobility in the shoulders.
Wasn't really saying which one is better, just making a side note about how weird it is, as I have switched back and forth myself between types of bars. The fixed bars at my gym actually have a bit of length past the plates so you can actually slide some of the older (small holed) plates onto the end to increase their weight incrementally. This was useful when doing 60kg x 10, as the fixed bars only went to 50kg and I personally liked the non-movement of the plates/bearings when performing this exercise.
that's pretty handy - I found olympic BB easier to get off the floor, but feel it more in my shoulders. I've looked at some external rotation movements to give a go (as much as I hate the thought of using cables lol), and an interesting one using a racked barbell on the trap then raising the arm on MobilityWOD. I've had tight traps lately too, so I'm hoping its just a case of needing more mobility work in that area.
At a guess I would say that the Olympic bar, whilst easier to clean from the floor in the first place (both due to height and being able to pivot/rotate the bar during the clean), is less stable once overhead and therefore requires a bit more controlled stability from the shoulders than a fixed bar due to the movement of the bearings.
A mate experienced the same issue when we got in new Ironedge bars for our benches...he really didn't like using these new bars because the bearings were so fresh that it made he bar feel less stable, requiring him to use stabilizing muscles he doesn't normally use during the bench press movement.
If your shoulders are markedly sore and you are concerned, I would give them rest until they aren't. Then look at either returning to the overheads or building up stability as per what rev said. You won't lose much strength in rest time, shoulders retain their strength very well and are very quick to build it all back up again after long periods of rest. It's the hardest thing to do psychologically but you really have to focus on the long term here. Take it from anyone who has chronic shoulder injuries, they really inhibit your ability to do much else in the gym besides legs.
I'm not having pain or anything like that, I can just feel it more in the shoulders. I'll try some assisted pullups, stretching etc then go back to my bench pressing and OHP and see if there's any difference after a week.
I'm probably just being overly paranoid, but it has been bugging me that my pressing movements are really lagging behind the rows, squats, deadlift.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
