Fair enough haha
Like birds said people aren't symmetrical, I ask about the arm thing because people overlook the most obvious stuff.
You'd be able to tell without measuring
Edited by r31slpr
Kate said my right hand sits lower than the left when standing, but that's the "low" shoulder.
Will have to measure.
Though I don't see how arm length affects how high the shoulder sits?
Or are you talking about discrepancies in length of bar travel in a movement, which makes sense but was not my original question.
Edited by ActionDan
Dan - have you had a spinal xray?
It's probably just not straight.
Mine is like a slight S bend.
My right shoulder hangs lower, further down my right hip is a little higher, making my right leg 5ml shorter.
You can't tell unless you really pay attention.
You can't do anything about it.
Apart from maybe run for local member of parliament.
I have never noticed this thread but so glad I have now haha
Anyway, anyone got some good exercises for traps? I struggle with getting some variety for my traps. Only thing I do is barbell shrugs, dumbell shrugs and upward rows.
farmer's walk, deadlift.
Has anyone tried 5/3/1 before? Thoughts on it? I was going to start it as my intermediate program, once I hit the 120kg bench and 200kg deadlift goals I currently have.
Ahhh I might give the farmers walk a crack. Looks like it's what I need. I need to deadlift but jsut can't figure it out and don't wanna put my back out haha
good for grip too. Only downside is the looks you get in the gym from carrying around dumbbells lol.
Haha yeah, that's the only thing I'm hesitant about. People will think I'm lost and can't find "my space" on the weights floor.
Yep. But not for long enough the last time I gave it a go.
Doing it again now for bench and OHP, Only at week 2.
It's great for some and not so much for others.
Give it a go and judge for yourself.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
