was recommended to be by Trent at PTC to mix in with some cardio to achieve some goals which are not just strength related but more total conditioning and health and fitness
if that at all made any sense
nah he probably like 83kg, shredded doe and tall-ish always wears belt and red singlet. youll know if I pointed him out - stays for hours lol
Edited by UNR33L
If you genuinely hold any of the top spots at your gym, it's probably a shit gym =\
No offense at all, as I think you've done great, as have many here, but I'd hazard a guess and say that most of us are average, maybe towards the upper end of average lifters (not me, but some of you) at best.
Unless we have some solid comp winners here I don't know about.
In my gym, I'm the top lifter.
Edited by ActionDan
I think I know what you are saying...
Our gym is a "Genesis Fitness Centre"...so top spot in anything is a title easily taken, compared to say, a lifting gym. I'm yet to see someone lighter than me deadlift more at my gym. I wouldn't care if someone did; would actually find it interesting and enjoy the competition of it, because right now I have to leverage my motivation to be stronger off of people at other gyms. And I did win our deadlift comp down there, so there's a degree of truth to what I said...but in the end it was just a joke, mostly referencing appearance/aesthetics because you mentioned "checking out" guys.
inb4 some tard doesn't understand this / read it properly and points out that someone at PTC is 10 years old 62kg and can deadlift 400kg.
My point was left about the lifts and what "spot" you have and more about the comparisons to other guys.
Like you said, there will always be a 10yr old at PTC DL'ing 400kg (I laughed at that).
So "spots" in your gym really mean jack, unless it's just a way for Leigh to pick up dudes?
Edited by ActionDan
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
