My wrists disagree with straight bar curls :(
Was just about to say this. It doesn't hurt when I do them but as soon as I rack the barbell and begin to release tension off my hands from the bar it hurts pretty bad...
PPP is good, will continue doing it for many cycles.
  • Like 1
I dunno about huge quads, they've certainly filled out my jeans now, but the main problem is severe lack of flexibility when wearing them lol
Can barely tie my shoes!
This is actually a really annoying side affect of lifting.
I cycle a lot as well as doing PPP + other lifting and when I get a few months of consistent training you really feel it in the fit of your tighter garments.
Combined with the trend in skinny jeans and shorts which is in full swing. Forget trying to fit your wallet, phone and keys in your side pockets. I swear my jeans, shorts, or suit pants have almost blown out trying to tie shoes.
Won't be fat if you're eating more.
Water weight.
Have you stopped taking any supps?
I've stopped consuming all of my supps for just over a month now, so probably the lack of creatine has helped to get rid of water retention.
Edited by L33SH
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
