not a bad office gym set up.
I tried to convince my boss to set up a gym here.
Only need some mezzanine flooring and then equipment. Dust was the major issue, but I thought we could put up some walls and then buy covers for the equipment which can be used before or after work.
He wasnt prepared to spend the money
Can't argue with that logic lol
I didn't read all of this but it's interesting that it says people with my blood type, B, have good immune and digestive systems, two things I'm renowned for.
I almost never get sick and I can eat almost anything without ill effect.
Important to note, there's been no clinical trials.
Scientific criticism[edit]
The blood type diet has met with criticisms for many different reasons,[2][3][4][5][6][7][8] some of which have been addressed publicly by D'Adamo.[16] A recent scientific review concludes that no scientific evidence exists to support the blood type diet theory and calls for properly designed scientific studies to address it:[17] "No evidence currently exists to validate the purported health benefits of blood type diets. To validate these claims, studies are required that compare the health outcomes between participants adhering to a particular blood type diet (experimental group) and participants continuing a standard diet (control group) within a particular blood type population."
    • Hi Fred, Are you still on here, I'm looking for 4 of these rims?
    • Looking back, I’m pretty sure I over-torqued the magnetic drain plug because I was trying to fully crush the copper washer. In hindsight, I definitely should’ve used a torque wrench. Either way, I ended up switching to a regular drain plug so I don’t have to deal with this kind of issue again. Big thanks to everyone on the forum for your support—I actually talk about you guys to my friends and coworkers
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
