Have you tried more explosive exercises like jump squats, squat presses/snatches etc?
yerrr... i do that stuff during the summer months when its nice to be outside.. and capoeira aswell.. so lots and lots of lunges and jumps... lots more plyometrics and lots less weights.
  • 4 weeks later...
Ok finally back into the gym again now (3 weeks running).
Fk im weak :D
EG: Bi curls I'm only managing 10KG 3 sets x 10 :)
I can't even do 2 dips lol
Gonna be a long 3 months to get back into even basic level of form.
At least I still have reasonable chest strength, although it's only machine at the moment till i get some reasonable base and then move back over to free.
Gday kunce,
My missus said to me the other day that she wants that buff bodied man that she had before marriage back. Seeing as we've been married for 10 years there pretty much no fucking chance Ill be able to find this dood so it looks like its up to me. I dont need to lose much weight nor put too much bulk on (cause im sxc as it is). I am planning on buying a home gym (weider is on sale atm), a rowing machine and a trainer for my pushie. Ill grab a straight bar and some dumbells too.
So,
I need advice on said home gym
Advice on a routine to suit
Thanks in advance bum monkeys.
Soon you'll be benching the 31 for a warmup.
lol RB26's, one arm each :ermm:
It's weird my BI's have lost massive strength, yet my Tri's (pushdowns) im almost doing the entire stack... However much that weighs.
Yet can't do dips as everything else is failing :ninja:
Same for legs, still good strength there interestingly
Yeah I know the feeling, and I only did 3 weeks away from the gym :ermm:
You should buy 2 build RB26's, remove sump, hand through bottom of block, and hold that crank like a dumbbell.
I've never been any good with the biceps :D even after the 3 weeks though I can still do 3x10 reps of dips with +15kg :ninja:
Gday kunce,
So,
<cut>
So what are your goals?
It sounds like you want to get a little fitter, and maybe lose some weight. Gaining muscle / losing weight is mostly diet.
Routine wise they're are a lot of things you could do, if your aiming for strength I'd recommend bench, deadlift, squat, military press , dips or similar.
Powerclean's are also great but they are a little technical, you also either need bumper plates or quiet a few mats on the floor to take the impact of the cheaper plates.
That's because you don't really use your biceps that much :ermm:
I found that legs maintain ok, shoulder / upper back strength you tend to lose quite quickly as well :D
lol RB26's, one arm each :banana:
Yet can't do dips as everything else is failing :P
use the assisted dip machine.
you're probably not isolating the triceps when you do the dips.
Anyone able to help me source the following in pill forms?
Ephedrine HCL
Caffeine (No DOZ id assume)
Potent Yohimbe
Am basically looking to make my own pre workout/thermo stack seen as hydroxy etc are a joke these days since the magical ingredient was banned. Thought id check with the pros before i went into a chemist or health store asking for these products and they look at me as if im trying to cook some gear lol.
Lol bananas,
so far ive found horny goat weed should substitute for Yohimbe cos it basically just boosts testosterone and energy. Ephedrine not sure as yet, but this is all legal as they can be found in Nutrex Lipo 6 which is on sale on shelves. I just dont want to cough up $70 per month for the stuff.
Just a standard ECY stack really, not a lot wrong with it.
Not really 'cooked' as such, plenty of information on the net for amounts to use etc.
You mean the tri-PD's? I have my shoulders locked and use abs to support me :)
I make sure i use nothing more than isolated tri's for those.
I'll give the dips a crack next week as i upped all the chest/tri & shoulder weights this week and am rather tender today.
Two more sessions @ this rate and i'll have a crack @ 5 unassisted dips on Monday :P
No I mean the dips.
you're prolly using your chest too much and your lower pecs are not strong enough.
If you can almost push down a whole commercial tricep pushdown weight stack then dips should be easy enough.
Ephedrine HCL
Potent Yohimbe
Been looking for Ephedrine for a while as well as Yohimbe, illegal & super hard to get a hold off
Caffeine is simple.. Most supp stores stock it.. ASN for example.. or you can order of BB.com ... I ordered 4x 100pill (200mg) bottles About $8aus each.. Great stuff to stack against your pre wo supps.. :P
Edited by Tomek
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
