Did my 1RMs tonight - 230kg squat, 200kg deadlift, 120kg bench, 70kg press. Stoked about it - I hit all the goals I was after, and squatted more than I thought I could. 8 or so months of PTC beginner routine and eating LOTS of protein.
Now for my 5/3/1 to begin!
Paradoxically the only thing to cure my calf doms was squatting.
Edited by bozodos
I always go below paralell Birds, I try not to have hamstring touch calf though. Still at 120kg or so unfortunately - diet started to get a bit out of hand again lately. Would have liked to got 240kg squat for double bodyweight, but I didn't want to fail it.
Can't really remember my starting numbers, they were pretty damn low though - when I started the PTC routine I was benching around 40kg, squatting 100 or so, and deadlifting 80. I had to do dips with ~90kg assistance, which I can now do bodyweight.
I've started doing stair / hill runs and sprints to get some conditioning in too.
Sensational man, really happy for you, so jealous of the Squat and DL =D
Happy because you've worked hard for it and happy because your attitude has been excellent since the beginning, no bullshit, no ego, just getting in there and getting it done.
*BroHug*
  • Like 1
Good work Boz. Only real powerlifters squat more than they deadlift!
Don't need to worry about knee wraps but a belt for squats is really handy, especially once it gets heavy. Just helps you keep tight and makes the whole thing a nicer movement.
It doesn't really protect your back and only maybe gets you a handful of kilos but it's definitely worth having.
Thanks Nick. I'll look into a belt - my Chuck Taylors are here so at least I'll have some reasonable footwear. I've had a strong squat and legs since I started, lucky I guess.
Been agonising over 5/3/1 assistance templates, I decided on Simplest Strength due to it having a squat and deadlift variant more than once a week, and not eating enough to give BBB a hard go
5 sets of 5, there's a heap of different programs, Markos always used to reccomend it more for lifters beyond the beginner stage, and I'd agree with that.
Common examples of programs are: Stronglifts, LP Greyskull, Madcow, Bill Starr's 5x5.
Cheers boz, I had a quick look online but thought id ask my fellow gym sauers. I had a chat with a 50 year old at the gym today. This bloke is bigger than most blokes at the gym. He said for me to shake up the routine ( 5x5, pyramid etc ) he swears by the pyramid program.
http://blackironbeast.com has a good calculator for 5/3/1.
I have started the boring but big program 4 day, very similar to the program I was doing but all the % and sets are done for you.
I will roll with this for the full cycle (about 9 months worth) from now and see how it goes, 2 days in so far.
I like it as it seems its a "get strong for dummies" type of thing, which suits me down to a tee.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
