No I mean the dips.
you're prolly using your chest too much and your lower pecs are not strong enough.
If you can almost push down a whole commercial tricep pushdown weight stack then dips should be easy enough.
mmm ye most possible.
Although it is fitness first lol, the stack isn't that big :)
And there are signs "do not double pin" all over so no doubt there are people having similar problems with needing more weight :P
Been looking for Ephedrine for a while as well as Yohimbe, illegal & super hard to get a hold off
Caffeine is simple.. Most supp stores stock it.. ASN for example.. or you can order of BB.com ... I ordered 4x 100pill (200mg) bottles About $8aus each.. Great stuff to stack against your pre wo supps.. :P
Damn not what i wanted to hear lol,
other option is seeing if this lipo6x can clear customs cos its ALOT cheaper in USA. Couldnt see any hidden ingredients, but as most know its hit/miss with customs so itd be a shame to spend money and get no product!
5'10"-5'11"
When i was training properly a few years back now i was sitting around 75KG's. Was more fit than outright muscle, but double my strength now easily.
Hell i might even be 82-83 haha, will have to check.
75kg at your height would be pretty thin!
i disagree, 75kg at 5'10 is fairly average. 70 would be fairly thin. if your doing push downs with most of a stack but struggling with dips it would make me believe thats a well small stack.
at goodlife i'll do push downs with a little over half the cable stack at the end of an hour long chest/tri/shoulder session and still be able to do 3X10-15 reps of body weight dips. i'm 78kg and 175cm tall, so i'm hardly what you would call huge....
Well i did skim the question its true lol,
BUT the first part says "what are peoples experiences" as if to say your thinking of trying it.
Haha, all good. I just told them to send either flavour. It's just when you buy 4.5kg, you kinda want a decent taste huh! :)
Adz, ever get anywhere with the WPI flavour investigation? Currently A1 supps are offering the Strawberry only for $115 or so...but buying 4.5kg's of a shithouse flavour is not cool. Maybe 1.5kg would be ok. So I aint risking it.
oh well done mate. you must be pleased with yourself
Hey mate, yep happy to say I've had both Chocolate and Strawberry and they are both ace, I think I might even prefer the Strawberry! It's great value stuff I reckon.
    • Man, I hope this one gets finished  i just randomly remembered it the other day and thought I’d check in.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
