did front squats today - with the clean grip I was doing it wrong cause it was loading up my wrists, was much more manageable with arms crossed, but I think I might have had the bar sitting too far forward on the delts. Did manage to get 5x100 out though.
Wow that's alright!
What do you guys think about dynamic effort and max effort body programs? I've been suggested a new program.
Here is a copy of the program, I would have to take out shoulder press and delt cable pulls due to my injury though. Please let me know your thoughts, thank you.
Monday – Dynamic Effort Upper Body – Focus on speed not weight
Flat Bench Press – 8 sets x 3 reps @ 55%– Focus on speed not weight
Decline Bench Press – 8 sets x 3 reps @ 55% – Focus on speed not weight
TricepsPressdown – 3 sets x 12 reps
Seated Shoulder Press – 4 sets x 10 reps
Dumbbell Side Lateral Raises superset into Front Raises – 3 sets x 10 reps
LatPulldown – 4 sets x 10 reps
Rear Delt Cable Pulls – 3 sets x 12 reps
Wednesday – Max Effort Lower Body – Squat or Deadlift
Max Effort Exercise (Box Squat or Deadlift) – Work up to 90% and do 3 sets x 2 reps
Seated Leg Extension – 5 sets x 5 reps
Straight Leg Deadlift – 4 sets x 5 reps
Glute Ham Raise – 4 sets x as many as possible
Front Squats – 3 sets x 5 reps
Abs/Core Work
Friday – Max Effort Upper Body
Flat Bench Press – Work up to 90% and do 3 sets x 2 reps
Incline Bench Press – 5 sets x 5 reps
BodyoverTricepPressdown – 4 sets x 5 reps
French Press – 4 sets x 5 reps
Seated Shoulder Press – 4 sets x 5 reps
Bent over Barbell Row – 4 sets x 5 reps
T-Bar Row – 4 sets x 5 reps
Saturday – Dynamic Effort Lower Body – Squatand Deadlift
Box Squat – 8 sets x 3 reps – Focus on speed not weight
Deadlift - 8 sets x 3 reps – Focus on speed not weight
Good Mornings – 3 sets x 12 reps
Seated Leg Extension – 3 sets x 12 reps
Glute Ham Raise – 2 sets x as many as possible
Abs/Core Work
Edited by L33SH
I'm assuming that's 55% of your 1RM, which you'd have a loose idea of.
I like my exercise to be very simple so to me that's a bit too involved.
I'm also not keen on splits where if you miss one day for whatever reason you miss that work for a week - but I realise splitting allows greater targeting and emphasis which is great for those with a specific goal.
I'd have a thought a full body workout x times a week would be fine for you Leesh, as you seem to want general fitness, well being, and some nice aesthetics. OR are you now looking to be a fitness model or something?
Mitch beat me too it, just times anything you need by the percentage number with a decimal in front of it.
That chick is too muscular IMO, but if that's your goal then a split routine will likely be a must, as will excellent diet.
You can do it!
Thats your speed day and your meant to be moving the weight explosively to train the muscle fibres and neural system, its not to try and build muscle.
Do a bit of background reading on louie simmons westside method and itll help explain the ideas behind each day
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
