Fair enough. What works for me is BBing hypertrophy combined with an upper body an lower body strength day:
Monday - Leg Strength + Core (deads and squats)
Tuesday - Chest (hyper.)
Wednesday - Shoulders and arms (predominantly lateral and posterior delts)
Thursday - Leg Hypertrophy
Friday - Back
Saturday - Upper Body Strength
BUT, this is just what works for me right now :yes:
AND, I change this layout every 4-6 weeks depending on other factors, next could be more strength dominant
Morning brahs.
I'm going to start my first foray in to fitness, initial aim is 5-6km jogging through hiking tracks 4 nights a week followed by some at home lifting/crunches/squats etc. I've worked an office job for the last 7 years so I figure this will be a good aim for first couple of weeks.
Is there some pre/protien/mix of supplements I should be looking at to help maximize workout?
If you're not already a runner 5-6ks daily might be a stretch but your body will tell you.
Get good shoes, and I mean trail shoes likle Salomons or something with Gortex lining, not Nike's they will get shredded easily.
As for Supps, basic WPI/WPC and some creatine will likely cover off all your needs as long as you're eating a relatively decent diet.
You can assess how well you recover before deciding if you need them as you'll mainly want them for recovery given your aim is fitness and not big strength gains.
Oh and as a fellow desk jockey, you're going to want to stretch a fair bit, it will help with everything. Sitters like us tend to have poor glute/hammy/hip flexor movement.
Edited by ActionDan
How's your DL'ing going Birds? You had some solid momentum at one point.
Average mate, I hit a bad bout of tonsilitis / yeast infection and lost 20kg off the bar from taking a couple weeks off. It's taking significantly longer to get the strength back :(
Back on the rise again, though. I think last session I pulled 100 x 10, 140 x 8, 180 x 1, 170 x 3.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
    • Was going to say something about flog, wife, pilates, behind but I better not... No dishonour here
    • Store bought, like dis  https://racecraftaus.com/products/muffler-oval-new?variant=39611886305393
    • As long as the bucket stays against the cam then it will measure up fine, the valve will close compared to a running engine but the bucket will stay against the cam lobe
    • I feel like i would be like most people who get these, excited for the first 3-6 months and then just totally forget about it. The end products do look sick tho. Ive got a 1/12 scale r32 model, dunno where im gonna actually display it once its all done!
