Ye I got the apple raspberry. I'm quite tolerant to pre-workouts and caffeine in general so we'll see how it goes.
Cool. The first few times I took it I had trouble getting to sleep at night, then I was fine.
Finally getting closer to pre-injury deadlift numbers. Managed 162.5kg x 4 tonight, no chalk or straps or belt. Felt really good, didn't have to grind too much either, so quite happy.
Bulkpowders.com.au do a supplement called "Thermocut".. Since I'm pretty sensitive to caffeine these days, I can't do pre-workouts. However 2 caps of these land 40mg of caffeine; enough of a boost to get focused. My training partner seems to like it better than his pre-workout, says the lesser 'buzz' feeling actually helps with the focus.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
