I recall looking into this when it last came up. Came across a "story" written by a guy who consumed what he feared to be a large amount (I think it was like ~400g/day), and when he spoke to his doc about it he was advised it was high but acceptable, for his size (he was like 200lbs built I think). The article then went on to explain how your body handles excess mercury etc which was pretty interesting
Edited by Trozzle
I do recall a few years ago of some athlete who ate a lot of tuna and having higher than norm mercury levels. I say it would have to be an isolated case. Well hoping anyways... I eat the best " John west " lol
Not me, I eat shitty Coles brand tuna and it tastes like ass to be honest. Meh, I eat tuna for the brotein, not the taste.
Well looks like I'll stick with my "2 cans of tuna a day routine" then haha :)
The trick is to time your purchase of tuna for specials...JW/Greenseas usually $1 a can at either woolies or Coles.
Or buy 4 pack of JW/Greenseas, which works out 1.50/can.
Yep, saw that come on sale right after I purchased 24 cans of Coles tuna. FML.
Hahahaha bad mistake
I gave the Coles tuna a go the other day, lemon and pepper
It tasted like a lemon meringue, disgusting
Yep, worse even was that I threw the receipt in the bin and couldn't exchange them for the JW ones :(
I made that mistake once, so I jsut stick to springwater now. There's an old saying about not being able to polish a turd..... hahaha
Edited by T.D
Give the JW or Greenseas lemon and pepper a go, it's much better. Hot chilli is good too but my digestive system didn't agree so no more :(
Will do mate, will keep an eye out and stock up hard when they're on sale again :cheers:
Hey guise - I don't have a build thread but I did a few measurements last night after 3+ months of solid gym work. I don't want to sound like I'm tooting my own horn too much, but I was really excited by the results; and most of my work in the gym has solely been attributed to information I've extracted from the health+wellbeing section on these forums. Much love brah's. :wub:
I started my first day weighing in at 76kg's, 174cm tall, 17.8%bf, thin, pasty, scrawny and generally weak as piss.
I started doing around 4 or 5 exercises of each upper body days, followed by lower body days, then a day off, then repeat.
For upper body:
Chest press 3x8
Shoulder press 3 x 8
Lat pull down
assisted wide grip chin ups
incline bench press
Military press
pull ups or bro curls
suicedes
rope pull for tri's/
For lower body
Squats
Deads
plate leg press
quad extension
hamstring curl
lunges
standing/seated calf raises
I would also try and do some hypertrophy stuff after each workout, mostly 30 seconds on/off on the rowing machine or spin bike. Or I'd do some sprints in the park or on the beach.
So last night, I weighed in at 78.5kg's, 18%bf, and a 7cm increase in chest width, 1cm decrease in belly circumference. 2cm gain in arms and legs.
tl:dr: Massively stoked that SAU fitness can provide excellent info. Cheers!
Edited by Floyd Westwood
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
