  On 21/08/2014 at 11:28 PM, L33SH said:
I don't do them
Got a comment last Saturday from a trainer at the gym, said my shoulders are looking amazing :)
Best shoulder exercise for making them look good is straight arm side raises. Bet you do a few of these hahah front raises to.
A overhead shoulder press is done standing, the weight is pressed without any leg movement and is finished with the weight overhead and your head "out the window.
But then my weight routine really only focus on strength training really not body building.
No I don't
I don't do any isolated shoulder exercises...
  On 14/08/2014 at 3:44 AM, Birds said:
This
Okay for an occasional form check, but you'll be more focused and "one" with the weight/bar and movement if your only sensory perception of things is the feeling of weight across your shoulders and progressing through the range of motion.
I started training a couple of days a week at the local PL club, and having to train without a mirror is the best thing I've done in a while. I actually found it hard deadlifting at the commercial gym staring at myself. That and using crappy liquid chalk and bars with no knurling; it's now ruined for me lol.
  On 22/08/2014 at 12:11 AM, triggerhappy said:
what do you put your shoulders down to? Its something that most people struggle to build properly
compound exercises?
I only do squats, deadlifts, bench, pull ups, lat pulldown, seated row and biceps at the gym...
This isn't the first comment I've had about my shoulders recently either.
The only thing I've changed recently is adding more sets to my bench.
Bench will give you decent looking shoulders as long as balanced with rows and deads to prevent hunching.
If you're bodybuilding you might want something more substantial, with overheads and rear delt work.
And that's not to say there aren't strength benefits from adding exercises like shoulder press, but you can easily do without and get decently strong with good looking shoulders.
All these bloody disclaimers I have to add these days lest someone get uppity that I missed out on something or bagged their routine.
Thanks for the ideas, I'm not really bothered about looks, training for strength.
My shoulder is still a bit dodgy and doesn't agree with bench, currently doing full body with standing ohp and dips in it.
Might try add some percentage based work like mlr suggested.
I couldnt bench 60kg a year ago and started rotator cuff excersizes every day and now got heaps of strength back in it. Still sore but can bench 100kg + depending how sore it is but i dont use a full range of motion
Bench isn't a priority for me anyway so I don't really mind. I did a bench session a few months ago and got 90kg paused for two reps. So it's not terrible I guess. My shoulder issue isn't rotator cuff related luckily.
Edited by r31slpr
See I have shoulder issues that prevent overhead movements, so bench is the only comfortable movement for me!
It really depends where you want the strength too...for me, in my sports, a horizontal push is more useful than a vertical one.
Funny story.
It was leg day today, started of with some bar warm ups then proceeded to follow my program and add weight as programed, weight felt heavy, I'm thinking its going to be one of them days, on about the fourth set I just manage to bust out 5 reps for 140.
Looking at my program I still had another 2 sets to go, a 5 x 152.5 and a 5 x 162.5, WTF....I thought I had deloaded.
I then put my glasses on and seen I was halfway through my Deadlift routine.
Note to self. Use larger font when printing program.
  • Like 1
pretty common. Rotator and scapular issues are the main ones. Thorasic spine issues and so on. Desk jobs + gym make it worse for people. Lots of internal rotation posture and then super strong internal rotation muscles vs weak/un developed external rotation muscles.
I had a turn of plenty of those injuries when I was much younger and then I learnt how to avoid them. Not had an issue since.
You could afford to ditch bench for 6months, then stick to ohp. Learn to do them from a clean. Learn to clean and ohp correctly(not behind the neck).
Rotator cuff excersises are fine but, once you have mobility back, the ones you ought to do for strength are face pulls or cuban press. Thorasic mobility and strength are important also. Rows and a few different movements you can get off youtube if you search.
shoulders like everything else are governed genetically. Alot of the asthetics of shoulders is also to do with bodyfat. Drop body fat and they look larger.
Edited by rev210
Bench 5 x 125 up 1 rep + 2.5, felt hard
OHP 5 x 77.5 up 1 rep and 2.5, felt hard
Dead 4 x 177.5 up 2.5, thought my head was going to explode
ATG Squat 4 x 142.5 up 2.5, thought my eyes were going to pop out
80kg (fat boy) 49yrs old.
  • Like 1
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
