God I love coming back to a thread like this after a while off, and seeing that the BS dribble-talk never stops.
Everybody talking like a lifting expert :rofl2:
so who are you referring to then?
Don't come back then :)
Its OK, we can forgive him, he is from Can Berra
Had a dexa scan yesterday. Results were as expected, skinny fat with not a great deal of muscle.
Will be interesting to see how I go in my next scan now that my training regime has become a bit more consistent
Post up results and pics
nohomo
when i had my last dexa scan you wouldnt want to see the pics hahah had the whole crutch everything like you would imagine xray glasses to be. Didnt happen on the first one though.
I was 96kg at 13% body fat and am 5 foot 10"
They are excellent i thought i was a lot fatter haha
nohomo
This
Will post when I get back to work.
Wish I was 13% lol
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
