  RBNT said:
Who can recommend a good brand of weight gloves? My hands are getting cut up due to the new nurling on the bars and attachments.
anything really imo
I used to have leather gloves but they ripped on me (after 5 years of having them mind you) now have the nonslip cloth material ones just because that's all they sold at the gym I go to
went without gloves for awhile coz cbf'd buying new gloves when my other ones ripped but started getting corns where my palm meets my fingers
  johnnilicte said:
friday
- have sex
Saturday (if keen)
- just arms, bicep curls, tricep press ra ra
- cardio
- try have sex with the missus LOL
repeat.
that explains it...
try having sex on the OTHER days to compliment your workouts & you'll notice an improvement
I suggest finding other female workout partners if your missus isn't available :D:)
I agree with some_cs_student, John...there's too much isolation going on there, too many exercises...particularly if you want to increase muscle size. And I see a fair bit of crossover in that routine...you should give certain muscle groups a bit more rest...rest is just as important as your workout.
$20-25 fingerless Harbingers from Rebel Sport...don't need anything special in this department. If you go heavy with the weights you'll still get corns with gloves but they won't be anywhere as bad.
On what lifts?
Your hands will get used to it over time, I use chalk for heavy deadlift's.
Although if you never plan on competing in power-lifting or similar than you can get away with gloves...since not using gloves I've found my grip stronger though.
Yeah, not lifting really heavy weights. I think the problem is the nurling, its pretty rippy. Ive actually split the skin on two fingers so I think gloves are the go at least until they fix themselves.
Hrmss.. so what should I be doing? I got some flab on the gut btw.. I wake up seeing a faint 6 but as soon as breakie goes in it's gone...
Any recommendations on the workout? I want to gain some more size & be tone... (I know I know, can't bulk and tone at the same time)
<cut>
Two problems there, your associating your workout with fat loss.
I don't agree with the bulking/toning, have a read of The Truth About Bulking
You can gain muscle and look more toned at the same time, its just hard to do. In fact, I don't agree with bulking/cutting cycles at all, have a read of The first 5 years
PTC - 10 GREATEST FITNESS/STRENGTH MYTHS read number 9 in particular.
Finally maybe try a beginners program?
Quoting Markos from that article "You are a beginner if you cant bench 100kg, squat 140kg and deadlift 180kg. I dont care what your bodyweight is, get bigger, its why your lifting. Bodyweight is not an excuse."
Also see my previous posted link :)
very interesting read!
yes, I am at work, I got in at 4:00 am to do an upgrade on a scheduling system, don't ask lol
Not sure if my routine (on the previous page) is any good though, might need some guidance on what I doing wrong.
  • 1 month later...
Hey all,
Just quickly does anyone know of a decent gym down south, which has free weights and cardio equipment?
Ideally somewhere along the coast between Nowra and say, Ulladulla, so including the Jervis Bay / Vincentia area.
Can't find much online...
Haha yeah, sorry didn't mention that I could be down that way for the holidays for a week or two and would like to be able to keep the routine... there will be plenty of pudding etc to work off :(
I can recommend you DON'T buy harbinger gloves, every pair I've had has ripped in the same spot - down the seam where the tag is on the inside. I'm on my 3rd pair (returned) and I've given up and am using them with gaping holes.
Serious man? I'm on my 3rd pair after like 8 years of training. I buy the cheapest Harbingers too :(
Are they tight or loose when you wear them? Gym gloves should be fairly loose...I see alot of people at my gym with snug fitting gloves and IMO this restricts movement and breathing. You can hold a pair of sponges and use them for grip, so gloves certainly don't need to be tight.
I got a set or urban Muscle gloves, fit good. I only using them on the rotating bar and for seated rows. ive used the Urban Muscle protein powder too, delish and gots the goods.
  Birds said:
Serious man? I'm on my 3rd pair after like 8 years of training. I buy the cheapest Harbingers too :/
Pink sponges definately... work the best. :(
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
    • That's not completely truthful now is it? Any flex fuelled factory cars also had the option to run on steam.
    • Yeah so I guess your mechanic would know turnaround better than me....but I would have thought you had access to same day or overnight rack rebuilds there....any big city here in Australia has that service.   There are a couple of o-rings and seals involved, I guess the risk is the part is specific not general. Other option is if you can have it on stands in your garage for a while, steering rack removal is pretty simple (2 mounting brackets, 2 ball joints (separate by undoing the nut to the top of the threads, put a pry bar between the steering arm and control arm to put pressure on it then medium force on the side of the ball joint or top of the nut with a hammer to break it free) and then the trickiest bit is the splines to the steering rack (not too bad to undo, one nut then it slides out, but mark it first so you can reassemble it straight)
