Purchased the WALKMAN W273S head set to belt out aggressive tunes to myself whilst training and swimming.
Excellent for only $70, really light and secure even doing wild out of control last sets of sleds.
Haven't swam in them yet but I did shower in them which was interesting.
  • Like 1
New squat PB of 80kg x 20 reps, all ass to ground and high bar. Up 5 reps from 15 last session.
WOW, simply one of the most intense pieces of exercise I have ever done. It is 99% a mental battle, standing there with the bar across your traps, the weight feeling heavier and heavier as time goes by, struggling to catch your breath and wanting to throw in the towel after every rep - I wanted to stop at 10 but had this insane drive to keep going and going. Racking it after 20 I promptly collapsed to the ground because my legs couldn't hold me up anymore lol. Took longer to catch my breath after that than my old 3km HIIT sprints used to.
So yes, painful and energy sapping as all hell, but so damn rewarding. Not looking forward to stairs and toilet seats tomorrow.
  • Like 2
I'm a bit sleight at the moment, weighing in at 81.5kg lastnight, so they were 98% bodyweight :)
Surprisingly my 1RM isn't going up, despite consistently adding a rep or two to the 80kg volume each session. Usually I can bounce one off the other (1RM vs volume) and vice versa.
With certainty in bench, I know that if I can get out 7-8 reps of 100 then I can do a single of 120 etc. Squats seems to be a different ball game!
A bit of empirical theory; I suspect that in the high volume squats I have more time during the set to gradually recruit each muscle in the chain, which could explain my second wind after 10 reps. Comparatively, a 1RM being a single rep, if you don't have everything doing it's part straight up, you won't be lifting to your potential. That and the lower weight squats are probably more controlled? Combination of lots of factors probably.
I was under the impression that anything around 8rm+ doesn't have the carry over to 1rm.
That could certainly explain my observations, and also why 1RM calculators are limited to a 10 rep input...though I always thought that was because the algebraic equations would blow out reliability with any number higher than 10.
Probably also explains why my <10 rep sets are affected by my intensity during a prior 1RM, yet I always have room in the tank for the high volume weights.
Would like to know the physiology behind it. Slow vs fast twitch fibers being used for one and not the other?
Can we therefore assume that if these different "strengths" operate independantly of one another, I could train both rep ranges in the one session (as I'm doing now) without them negatively impacting each other? Creating a rounded combination of strength and endurance?
As an aside to this, when I was training low weight bench for a couple weeks I got my 60kg reps up to about 27-28 and my 1RM was probably around 115, however during my strongest 1RM period (122.5kg), when I had mostly been focusing on low rep sets, I gave the 60kg challenge a shot and only completed around 23 reps.
Depends I guess, your training methods have proved to be slow progressing in the max/1rm scale (not starting an argument).. So they must affect each other.
If you focused on one or the other in cycles I'd assume you'd have greater (quicker) results in both areas.
Most training cycles start with higher volume/intensity in the earlier weeks and taper down to peaking. But, they are generally always reps for more weight, not weight for more reps.
Morning all.
I'm still here, doing little more than maintenance these days due to work, not great sleep, long winter season of illness etc. Lost 5-6kgs (not intentionally and it sucks, but hey, more abs) and am only getting 3x 30-40min sessions a week these days so unsurprisingly my strength/size has/is also going backwards.
Because I cannot easily control the factors affecting it, what's the best approach to try and minimise the losses? Drop the weight so I can get out the full rep/set scheme (3x8 in most cases, 2x15 on squats bu they are only light and are a special case due to my back) or continue doing what I've been doing which is struggle but keep adding sets to get the full volume out. as in 8, 8, 5, 3 or 8, 7, 6, 3 etc.
Good to see you guys (and Leesh) still cranking out your sessions :D
  • Like 1
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
