Cheers man. Didn't use to be. This section is completely new (like yours). The old section is still very "health club" like. Souths Juniors train here occasionally and they've got their first PL comp being held here next month.
Sounds exactly like my gym. Until now I'd been deadlifting in any open space I could find amongst the incline benches etc. Not all bad as you get to look good lifting heavy in front of people, but nothing beats a good platform and bar!
I'm gonna look into seeing if I can get my gym to put up a members record board.
^^ I agree. I hate the slippy slidey cross-fit style bars. I need proper knurling in the middle too, for squats.
You mean oly bars? The ones used for the Olympic lifts, not cross fit.
Iron edge bars have hit and miss knurling, couple I've used cut the hands up beyond a joke, not cut right or something, others are good.
So took my week off, ready to come back for a light session last night, went to be early instead due to flu, can't catch a break.
Just cannot catch a break. Drinking juice, taking multivitamin, eating yogurt, up'd protein intake, just cannot seem to get a run of more than a week or 2 of being somewhat "healthy".
Need some decent sleep too, being a parent is equivalent to having Ebola on every surface in your house :)
Other parents tell me it starts to improve after about 2-3yrs...
Basically yep. I think all our texas bars have the knurling in the middle except one or two that are dedicated for bench. We got 2x dedicated squat bars which are 25kg and thicker as part of the buy.
fancy gyms there - t the PL club I train at has mostly the ABC black anodized bars, there is a couple of Iron Edge ones that have finer knurling, they all feel pretty good to my hands, though the Iron Edge ones cut into the top layer of the skin with heavier deadlifts.
And shoulder, back and trap are le f**ked.
Have had some discomfort in my right shoulder particularly for awhile now but as of yesterday on bench it is now much much worse.
Booked in for a physio see what they say
Not good Mitch :( Hopeful you can just rest up and need nothing more than that.
I've made some small adjustments to my routine to hopefully stop going backwards, added weight, dropped from 3x8s to 3x6s for a while to build a little more strength again.
A guy here said he had huge success with back extensions/morning glory type exercises so I've removed the back plank I was doing and added swiss ball back extensions, trying to up my eating and get to bed earlier.
See how we go over the next few weeks.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
