I now wear stretchy material / loose running shorts, which finish a few inches above the knees. When you're a tall guy with long legs this makes you look like leg day is a once a year occurrence for you, but the range of motion is awesome and uninhibited - might as well be squatting naked.
Thinking I'll have to find something above the knees too, my legs aren't skinny though so shouldn't look to bad
I grabbed some UMBRO soccer shorts which work well for squats/everything, for footwear I use Chuck Taylors and soccer socks for deads to stop the blood if I hit my shins.
I do tuck some of my shorts into my undies to shorten then up a bit when I'm doing front squats as I find it more comfortable.
I'm not a fan of compression gear for lifting, it makes my junk all tucked up and uncomfortable.
No offense to any geared lifters out there but the gear they use makes me LOL and think WTF.
I have legit never had a pre-workout of any kind unless bcaas fit in that category.
I dont even drink coffee so I feel like I could probably benefit from something but ive never really felt the need honestly. All the ones that had good rep are banned now arent they?
fk ur pre workout
Just listen to your fav pumping music and go make that gym wish it were never born
  • Like 1
Bulk Nutrients NO3X. Give it a shot if you want, I find it quite decent and I have a small tolerance to caffeine/stims now (not as bad as I used to, but now I restrict my caffeine intake and basically never use pre-trainer either)
Also Dan, I might partly go back on my words from yesterday regarding MACA. I downed a heaped teaspoon on an empty stomach yesterday morning before heading to the gym, and by the time I got there (maybe 20 mins later) I was feeling a lot more awake and motivated than usual. Could be down to anything, so just went with it.
However this morning I figured I'd repeat the teaspoon on an empty stomach, and again shortly afterwards I feel better than usual. Particularly so after I've had a coffee.
It may very well have noticeable effect when you give it a chance by cutting out other variables haha (empty stomach), so I'll keep doing this teaspoon of MACA before I leave each morning to see if it continues :)
Still sceptical though :P
fk ur pre workout
I must say since i have ditched coffee and pre work out i have been sleeping and feeling a lot better. A lot more solid sleep too. I was previously taking a few different prescription sleepers. I had a lot of trouble sleeping. It took about two weeks after i stopped them to notice a better sleeping pattern. Much much easier to eat as well.
I have never been into PWO, tried craze once for a laugh and couldn't get to sleep until very late.
TBH, the DAA test interested more from a libido POV, but better sleep fixed that.
The maca powder interests me in terms of focus throughout the working day.
Have you had blood tests get a full hormone panel done.
Small dose of test can do wonders for all the things you mentioned and if you have low test its prescribed and covered by medicare :)
No the "issue" wasn't that serious, just a decline in my interest levels, it;s been almost 8yrs though and we'd had a pretty full wind up towards the end of 2014. As you might recall I was also getting sick quite often etc. Ella has finally stopped catching every disease and bringing it home, I'm making sure I get enough sleep, taking a multi again, making sure I get some good greek yoghurt in (probiotics) etc so I'm feeling better and have had more "interest" as a result.
I have a tendency to play down/disregard the effects of work related stress also as that's not exactly manly when I work in an office all day, but the reality is it does actually seem to take a toll on me over time. There was/is some big things happening here - good things, but lots of work regardless.
Know exactly what you mean!
I am going through much the same gym is about the only thing keeping me focused at the moment.
I don't mind pre-work out
Gets you in the mood if your not, and sometimes makes you feel like an energiser bunny in the gym
what numbers are you aiming for at the comp?
Semi related, what pants are you guys and girls squatting in? I just had a massive blow out
not sure what numbers for the comp as it's my first, I'll open with something like 190 sq, 170 dead, 100 bench and go up. General consensus is to start with something you can do for 3. I wear stretchy shorts that end midway up the thigh. Had several blowouts with other types of shorts due to my low squatting, these are basically untearable. Got them from Big W (though they no longer appear to sell them).
Good numbers. Wish i could squat as much as i could dead or better. I can get 200kg out on a dead somes days for 2 reps. Squat 140kg for 1 or two going full depth. Even thats a struggle.
Decided to get a bit more serious and start getting organised and planning meals for the week.
Hopefully it helps. Will do some more meals up tonight and freeze a whole bunch, so I have healthy meal options at my fingertips.
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I鈥檝e made some progress.    had to put extra notes in there so I don鈥檛 stuff it up 馃槀
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
    • So I ran into the same problem. I got stuck in the cycle of again of putting putty sanding it, putting putty sanding it, because of a low spot. And notice my block is not completely flat with the panel, even though it's a long block. My panel is slightly curved. Is this an issue? Do I need something that matches the door perfectly, or no?    I do have the smaller flexible block that covers the width of the repair just not the length, I was experimenting with it again to but seems to be the same issue
