Haven't noticed any difference energy or strength wise, its not like you stop making your baby batter, you just don't fire the stuff out the barrel, like everything lots of people have lots of different views and opinions of the procedure.
Just like the good "General Jack D Ripper" said, "I do deny them my essence".
And I don't need to bother with the half concern concept, some do, not me though.
Just glad I can do the exercise again after all my shoulder troubles in the past, let alone set new PBs - human body is an amazing thing sometimes!
It really motivates me knowing there are people my weight easily benching 160+
Gives that perspective that what I'm doing and aiming for can be easily accomplished
  • Like 1
Which is exactly why the last time I deadlifted anything, it was that 190kg PB well over a month ago hahaha
I know deadlifts are pretty much THE BACK EXERCISE, PERIOD....but given I'm not too interested in powerlifting specifically, I'm forgoing on them again for a while. At least when I'm keen to include them again, I'll start from the bottom again ensuring form is immaculate by taking advantage of an offer put forward by the (now former) owner of Elite Physique here in Canberra - Billy Giampaolo - to show me how it's done haha. Ahh, Billy's a legend.
I did that too...took a sabbatical from them to focus on squats and rest my back, as my back was starting to get regular stretchy feelings especially with the regular 1RM attempts. Glad I did because my squat has come up a fair bit from what it was and now I've reintroduced deads, they are much lighter but I have heaps better form.
Always good to reset form once in a while and take a break from a particular exercise, particularly when you're not competing in lifting or anything. Sometimes it's as good as a break from the gym.
Yeah im on average 6 days a week no cardio. If i add cardio i dont drop any weights days either.
Been riddled with sickness lately been thinking about having a full month off. Dont think that will happen every time a try it doesnt even last a week. Did someone say ADD i can never sit still!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
