2 days of snowboarding this weekend, should make up for leg exercises for a while....
Though I'm so NOT KEEN on the part where I'll be CAMPING IN A TENT Friday and Saturday night, just inside the national park (so likely on top of some snow)
Yeah a few of us camped out for a week when the blizzard was on a few weeks ago.
Make sure you take a small shovel, dig out the snow then lay your tent on the harder snow below or on the ground depending on how deep it is.
You taking in food and water or you living out of your vehicles?
Nah, not going THAT far. Just inside the national park - Sawpit Creek I think it's called. Won't require clearing any snow, though there will likely be a small layer of the stuff down.
  • 3 weeks later...
slightly odd question, but does protein powder make any of you guys do really stinky farts? seems to be that a few hours after i have some i start producing the sort of gas i could sell to the army as a weapon......
Varying effects...some people get it all the time for as long as they take protein, others only when they first start up on protein (stomach sickness can be common too).
Completely normal though. Just like it's normal for the starting deadlift position to result in similar things...
So RUMOUR has it Zyzz is dead. I've only been told by 2 people who read it on Facebook or something....is it for real? I wouldn't be surprised if it's a load of shit he or one of his buddies have started for lulz
I had major issues with the Max's stuff i used years ago.
Using the Bulk Nutrients stuff, no issue at all even using Milk which can set people off.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
