Anybody recommend somewhere online to get a dips belt (to hang weights from)? Planet Max here in Canberra is only place I've checked, and the only one they stock is $59 (probs ok, but steep until I know what's average)
sounds reasonable
i'd be more interested to know where you can get chains like these
I found some chains here:
http://www.gymdirect.com.au/product-search-result.htm
But you would be bankrupt (and amazingly strong) by the time you looked like your above post.
if you want chains just go to your local boat shop, or even a fishing shop. you can get some pretty decent size chains (anchor chain, they sell it by the metre and it's cheap), and they are usually glavanised so sweat shouldn't be an issue rusting them, LOL.
still not a bad investment considering you can use em for dips, curls etc
Ehh if you reckon that's reasonable then fair enough, tomorrow ill grab one ;)
here you go http://www.worldfitness.com.au/product_info.php?products_id=557 seems to be the running cost for em
hmmm hadn't thought of that...
i've checked out hardware stores only but they don't really have the right size/weight
you just need a weight belt and a short length of chain or rope... better than chains IMO as you can hang different size plates from it and be pretty specific about what weight your lifting... you also don't have to lug weight to and from the gym just a belt
then you can use the weight belt for squats/deads etc... if you just get a dip belt you can really only use it for dips/pull ups
So you reckon get a support belt or whatever they are (for heavy lifts) and then just hang a rope from that with the plates on it? hmm, double use I suppose.
I meant the exact type of thing someone linked in response to me - the belt with chain that you hang plates from anyway. It only has a single use though, doesn't provide support if I wanted to use it with deadlifts or something
Either way, I'm gonna rock on over to planet max today and see what I'll get
http://shop.ebay.com.au/?_from=R40&_trksid=p3907.m570.l1313&_nkw=weight+dip+belt&_sacat=See-All-Categories
$20-$30
But I'd be going with Nick's idea...don't see the point in having a different belt just for that when a normal belt with a chain will do the same thing
I just put them between my thighs and lock my ankles..
inb4thatswutshesaid
I always wanted a belt, but couldnt justify spending $x for one excercise. Now I do multiple excercises which could utilise a belt, but still couldnt justify.. lol.
[/quote
arent u a clever boy! lol wish i thought of that before i brought my dips belt now... i got a leather one on ebay i do like it though and get alot of use..
how many of u guys actually use a weight belt for deadlifts and squats for your back our of curiosity? and how much weight would you want to be able to dead lift before using one do you think?
I can't claim the idea, there is a weight belt at my gym setup like that... I only use the belt for weighted dips/pull ups... I have never used a belt for squats/deads etc
no idea when you should look at using one... I'm still under 200% bodyweight on those lifts so not sure I need to use one yet... and I don't do 1rm
I went to the gym at lunch today, gym is too packed after work... think I'm going to make lunch sessions a regular thing... I can't get up early enough to go before work lol
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
