this one is i have taken from sydneykid in the coilovers thread. we got to talking swaybars.
  Trust33 said:
Thanks for the advice Gary. Atm im on a full whiteline stabiliser bar kit with urethane bush set, camber front and rear and pineapples set to standard.
the front adj blades on the swaybar im pretty sure though i could only get set up at 2nd and 3rd hole. can the front swaybars be adjusted any further? how can i do it? the rear is at full hard.
  sydneykid said:
What size bars are you using? My guess is the off the shelf 24 mm front and 22 mm rear, which is too narrow an adjusment range for the track work you are doing, grip or drift. You should really be looking at 26 or 27 mm front and 24 or 26 mm rear. I don't recall what model it is, if it's an R32 then you need 4 adjustment settings on the front and 3 on the rear, standard (off the shelf) is 3 front and 2 rear. If it's an R33/34 then you need 6 adjustment settings on the front and 3 on the rear, standard (off the shelf) is 5 front and 2 rear.
You should also be using spherical bearing links on the bars to give you the instantaneous effect, plus increase the feel as you need as little dampening of the response for track work. They will need regular replacement, even the Whiteline greasable and dust covered ones. Just like brake pads they will wear out, they are a consumable after all.
To give some adjustment for the usage patterns that you have, you can't run spring rates that high, anything much over 5 kg/mm front and 4 kg/mm rear will negate the effect of any adjustment (bars, shocks or geometry) that you do. Use the bars to control the roll, that's their job after all and then adjust the rear subframe geometry to suite the traction requirements. At the moment you have nothing to adjust that will help with your problems.
Cheers
Gary
  sydneykid said:
Somethings to think about;
You would need to use twice the spring rate to achieve the same anti roll as a stabiliser bar. Why? Because the inside wheel goes down the same amount that the outside wheel goes up. So a stabiliser bar has twice the movement for the same amount of roll as a spring, hence twice the amount of resistence to roll. Only the outside spring resists the roll, the inside spring does nothing.
When you are not going around a corner, the stabiliser bar does nothing, so you get more traction from the softer spring rate.
Stabiliser bars are easily adjustable, spring rates are not. If, on any given day, you need more or less front or rear anti roll you can't easily, quickly or cheaply adjust it with springs. That's why (when the regs allow) race cars have driver adjustable stabiliser bars.
Diagonal weight transfer is best resisted with anti roll, not spring rate. Under corner exit acceleration the outside rear tyres take a large amount of weight transfer, this manifests itself as lift to the inside front tyre. Reducing inside front tyre grip means that the outsdie front tyre is carrying more of the cornering load than would eb the case if the diagonal weight transfer was a resisted by a stabiliser bar. Excessive outside tyre wear and inability to maintain consistent lap speed due to overheating are all systems.
Too little anti roll has side effects. One of which is the need to run excessive amounts of camber, front and/or rear. This reduces the contact patch of the tyre for straight line acceleration and braking.
Running an excessively high spring rate becuase of a lack of antir roll has a few more side effects. One of which is the need to run excessively high rebound damping in the shock absorber to control that higher spring rate. This means the shocks resists (slows down) the downwards movement of the suspension and makes it more difficult to keep the tyre in contact with the road surface. Skipping from small bump to small bump is not good for traction.
I have several more pages in me if necessary, if anyone remains unconvinced.
Cheers
Gary
Selby's swaybars (not sure if they make swaybars for Skylines) -
http://www.hotfrog.com.au/Companies/Selbys-Swaybars
K-MAC swaybars (As far as I know the prices on the website are in US dollars
and they make swaybars for R32, R33, R34 in non adjustable and adjustable).
K-MAC website -
http://www.k-mac.com.au/
Swaybar prices -
http://www.k-mac.com.au/pages/tuning/listofkits.htm
Also I noticed they can custom make springs.
Edited by SKYPER
K-MAC website -
Swaybar prices -
I thought Selbys was Whiteline?
Anyway thanks for the info and links .
  [Michael] said:
they are hollow bars.
size f: 24.2mm
size r: 27.3mm
i use the gtr spec ones but they bolt onto my gts fine
gts spec ones are
f: 27.2mm
r: 23.0mm
Where did you snap these up from and how much did they set you back???
size f: 24.2mm
size r: 27.3mm
gts spec ones are
f: 27.2mm
r: 23.0mm
Front GTR (4wd) bar won't fit a GTST (2wd), plus it is too soft a rate.
Cheers
Gary
  evil_weevil said:
Gary,
I have forgotten....what are the size of the sway bars in the GB that I have? :P
From memory, 24 mm solid front adjustable and 22 mm solid rear adjustable.
Minimum adjustment is equivalent to a 27 mm hollow bar, with 6 steps of around 8% increase each on the front.
The rear is equivalent to a 24 mm hollow bar, with 3 steps of around 12% increase each on the front.
All the Jap hollow bars I have tried are grossly underdone. As an example, we swapped John's 300ZX hollow bars for some solid bars, backed off the spring rates a bit and it was 1.5 seconds a lap faster at Philip Island.
Cheers
Gary
  • 2 months later...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
